2000-Watt Portable Indoor Generator for Home Emergency
Rainy season power outages and grid failures have grown common in the United States. About two-thirds of the U.S. populace is at the risk of blackouts stemming from harsh weather conditions. That is the reason more and more people are electrifying their houses with emergency backups.
In our opinion, the best emergency backups are portable solar generators. They convert the solar energy collected by panels into usable electricity. This electricity can then be utilized to power devices during unexpected blackouts.
This comprehensive guide is about portable indoor generators, particularly those affordable 2000-watt generators. It will provide some top recommendations for the best solar generators for emergency situations, along with safety precautions and maintenance tips.
Why Do You Need an Indoor Generator for Emergency?
Indoor emergency generators can be your saviors in the event of rainy season outages, grid failures, or other unforeseen situations. They provide much-needed electricity for your vital appliances like laptops, heating/cooling systems, and communication devices.
Unlike outdoor power stations, indoor generators are designed for safe operation within homes or apartments - that means harsh weather conditions won’t affect them. They also eliminate the need for extensive wiring and minimize the risk of theft and vandalism.
Indoor generators usually come in two fundamental types: inverters and solar power stations. Gas-powered generators are not included in this list since they rely on fossil fuels and emit harmful fumes like carbon monoxide, which makes them less safe for indoor use.
Now, let’s explore two types of indoor generators in some detail.
Inverters
Inverters are battery-powered and are generally connected to an electrical source in the home. They store power when the grid is working appropriately. This power can then be used when the grid goes down.
One major limitation of these inverters is their low capacity. So, you may not be able to power your whole household using an average-sized inverter.
Solar Generators
Unlike gasoline generators and inverters, solar-powered generators utilize the sun’s energy to operate kitchen appliances and other tools. They are known for their eco-friendliness since they employ clean energy and don’t emit harmful toxins.
Although they are small, they have relatively high capacities and can even power critical appliances, such as CPAP machines.
What Can A 2000-Watt Solar Generator Run?
A 2000-watt solar generator can run a variety of appliances depending on how much power they need. Below are some common household appliances with their running and starting watts - these can easily be operated using a 2000-watt generator.
Appliances
Running Watts
Starting Watts
Ceiling Fan
60W
70W
Hot Water Dispenser
1,200W
100W
Blender
300W
800W
Rice Cooker
200W
500W
Coffee Maker
550W ~ 1200W
0W
Television
500W
0W
Mini Fridge
200W ~ 400W
1,000W ~ 1,200W
Desktop Computer
100W
350W
Home Internet Router
5W
15W
Laptop
50-300W
0W
EV Home Charger
1,600W
1,800W
Clothing Iron
1,100W
0W
Top 3 BLUETTI 2000-Watt Solar Generators
Now that you know an indoor generator is a reliable energy backup for emergencies, you may be eager to purchase one. To help you make a good choice, we have already curated a list of the best yet affordable solar generators.
You can select the one from the below-mentioned generators based on what features appeal the most to you.
BLUETTI AC200P Portable Solar Power Generator
bluetti ac200p
The BLUETTI AC200P is a true embodiment of reliable energy. It will keep your devices charged at all times, whether you are experiencing a power interruption or want protection against potential energy price hikes.
What’s the real deal? The AC200P has 17 versatile outlets, which include USB-A, USB-C, a cigarette lighter connector, and 12V/3A DC ports in addition to the standard AC outlets. It also incorporates a 12V/25A RV port and a 15W wireless charging pad for your convenience.
The AC200P 2000-watt solar generator is both durable and safe for indoor use. It incorporates the safest LiFePO4 battery technology that provides over 3,500 charging cycles. In other words, it can withstand daily use for nearly a decade.
In addition, it has a sophisticated battery management system, which monitors every aspect of its performance. It safeguards your AC200P against potential risks that may arise during day-to-day operation.
BLUETTI AC200MAX Expandable Solar Power Generator
bluetti ac200max
The BLUETTI AC200MAX is not your average energy solution. It arrives with a powerful 2,200W pure sine wave inverter that can keep all your essential gadgets working without a hitch.
The AC200MAX comes with two expansion ports where you can attach two BLUETTI B230 (2,048 Wh per pack) or B300 battery units (3,072 Wh per pack). These units can bring the total capacity of your AC200MAX to an incredible 8,192W - this is enough to stay off the grid for two or three days.
The AC200MAX can accept a solar input of up to 900W. Also, you can use both solar panels and a wall outlet to charge it quickly at a blazing rate of 1.400W. So, with the AC200MAX, you will always be prepared to tackle any emergencies. It will be full in less than two hours.
The AC200MAX has 16 outlets that can be used to charge multiple devices at once. It also has a 30A NEMA TT-30 plug and a 12V/30A DC outlet built in - that means you’ll always have power wherever your circumstances take you.
BLUETTI EP500 All-in-One Solar Power Generator
bluetti ep500
The BLUETTI EP500 is an inclusive energy solution that can meet all your energy needs during an emergency. With up to 15 outlets and an astonishing capacity of 5,1000 Wh, the EP500 can effortlessly power your kitchen appliances and other home gadgets and electric cars as well.
The EP500 is different from other indoor solar generators in the industry. It features a built-in dual-core microcomputer whose software can easily be upgraded over an internet connection. Because of these things, the EP500 is worth a buy since it keeps on getting better.
Unlike gasoline generators, the BLUETTI EP500 keeps your lights on and charges your devices without any upkeep, fuel, carbon monoxide, or annoying noise. The EP500Pro can be paired with up to 1200W MPPT solar input for quick charging or to keep your appliances running without draining the main battery.
The deal also gives you peace of mind with a good 5-year guarantee. With its LiFePO4 batteries and smart tracking system, the EP500Pro is a reliable source of power for a variety of situations.
Tips for Choosing the Right Indoor Generator for Home Emergency
There are numerous things you need to consider when buying an indoor generator for home emergencies. The important ones have been discussed below:
Power Output
Select a generator that is strong enough to run all your essential devices and appliances. For this, you will need to check the wattage needs of those appliances that you want to power.
Battery Capacity
The duration of time a solar generator can supply electrical power significantly depends on its battery capacity. So, make sure the generator you choose has enough rated power to accommodate your needs.
Weight and Portability
Choose a solar generator that is easy to move and doesn’t weigh much. These qualities are particularly important during times of emergency.
Charging Time
The solar generator’s charging time represents the time it takes to charge the battery, either using solar panels or a wall outlet. The charging duration may vary by the generator’s capacity and the amount of sunlight. Go for a generator with short charging times since emergencies wait for none.
Durability
When buying an indoor solar generator for emergencies, selecting one that is durable enough to handle rough use is crucial. Choose a generator made from robust, high-end materials.
Added Features
Some indoor generators also include some additional features, such as LED lights, AC outlets, USB ports, and advanced battery management systems. While they may come at an additional cost, they are worth the price for home emergencies.
Related article: Solar Battery for Home Energy Storage Buying Guide
Emergency Preparedness: 5 New Home Battery Backup Solutions in 2023
Safety Precautions and Maintenance of Using Indoor Generators
Using an indoor generator is an excellent way to get renewable energy for miscellaneous uses. But, like all other devices, it also demands you to follow some safety precautions. Regular maintenance is also necessary to keep your electrical equipment in its prime condition. Here are some of the things one should never undermine:
  • Ventilation: Keep your indoor generator in a space with good ventilation - this will prevent the build of heat during charging or use.
  • Water Exposure: Water, the basic necessity of life, can also pose some electrical dangers since it can conduct electricity. So, keep your indoor generator away from water or damp places.
  • Overload Protection: Be aware of the generator's maximum capacity. Please don't use it to power appliances whose running wattage requirement is beyond its capacity.
  • Fire Safety: Every one of us knows about how dangerous fire is. It can even burn your entire house, and solar generators are no exception. So, keep your solar generator away from fire sources. For extra safety, consider installing smoke alarms in your house.
  • Equipment Maintenance: Regularly check your panels, wires, and connections for damage or rust. If you observe something unusual, fix it as soon as possible to avoid grave consequences.
  • Manufacturer’s Instructions: Manufacturers have the best knowledge about their products. So, never ignore any particular care instructions provided by them.
Do energy shutdowns often trouble you? Investing in a solar generator can free you from all your energy-related worries and keep all your devices functional.
BLUETTI indoor solar generators are ideal for home emergencies. While their AC200P is a portable energy solution for medium-sized homes and apartments, the AC200MAX is expandable, and the EP500 can smoothly power 99% of household appliances.
If these don't resonate with your energy needs, have a look at other viable options on the BLUETTI website. You will surely find a perfect energy solution there that fits your energy requirements
