Emergency Preparedness: 5 New Home Battery Backup Solutions in 2024
The world is now a digital era where everything runs on power. Amazingly, everyone is dependent on electricity for one or other household tasks. In this scenario,  having a protective layer of home battery backup means peace of mind.
Blackouts are common with aging grid infrastructure, harsh weather conditions, and other failures. Therefore, a constant and reliable power supply is crucial for any household. Luckily, you can have it with efficient battery backup at home. They store power and are helpful during power outages or technical failures.
To make the best purchase, you must look for a system that aligns with your electricity needs. To guide you, here are five new home battery backup solutions in 2024 and other important information.
The all-new BLUETTI EP900 + B500 Home Battery Backup is a perfect companion for all your home power needs. It has a scalability of 10-20kWh capacity, up to 9,000W of power. Also, it can run all 20V and 240V devices. So you don't have to worry about energy consumption.
Its other features, like the option to sell extra electricity to the grid, smart control with the App, and more, make it very convenient and cost-friendly. Also, with a ten-year warranty, hassle-free installation and amazing post service, you don't have to worry about anything.
Furthermore, you can expand it up to 9,920Wh~19,840Wh according to your needs. In addition, it uses a LiFePO₄ battery, and its IP65 is water-resistant, which means you can install it indoors or outdoors. Its modular designs and sleek looks are another not to miss feature.
Pros:
  • It's expandable.
  • It can be installed outdoors and indoors.
  • This system is compatible with existing and new solar solutions.
  • You can sell extra electricity back to the grid.
Cons:
  • It can be a bit expensive.
BLUETTI AC300 + 1*B300 Home Battery Backup
The all-new and flexible BLUETTI AC300 + B300 Home Battery Backup is your solution for 24*7 power. The best part about this system is its flexibility, expandability, and great price.
It's a 3,000W AC pure sine wave inverter with a 6,000W Surge. Moreover, it has a 3,072Wh capacity, which can be expanded to 4 × B300 for 12,288Wh, which is groundbreaking.
You can boost the charging input from 1800W to 3000W according to your needs. Moreover, you can get up to a 5,400W Max rate with wall outlets and solar panels. With fusion box pro, you can get 240V/6,000W output and a total capacity of 24,576Wh(4 B300s for each AC300).
Plus, it's seven-ways chargeable with AC/Solar/Car/Generator/Lead-acid Battery/Dual AC/AC+Solar. Also, with a LiFePO4 battery with 3,500 Life cycles to 80%, it's the most reliable product. It ensures you have access to power with its expandable and flexible features.
Pros:
  • It's expandable.
  • You can charge via different inputs.
  • It's budget-friendly.
Cons:
  • You may not be able to sell extra power to the grid.
BLUETTI EP500Pro Home Backup Power
The all-new and modular BLUETTI EP500Pro Home Backup Power ensures 24*7 access to power. It's a 3000W-rated pure sine wave AC inverter with a 5100Wh LiFePO4 battery.
The best part is its movable power station which can be reallocated to any area. Just imagine taking it to the lawn for a party, picnic, or anywhere. Just recharge it and carry it anywhere.
With 15 outlet sources, you can power any appliance. Moreover, it has a built-in dual-core microcomputer and internet connection, which means you can update it with the internet from your phone.
It keeps on all your appliances and lights running with some smart features. Moreover, it's quiet operation is a blessing. You can also power multiple devices simultaneously and control them with smart touch operation.
Pros:
  • It's movable.
  • It has smart features for control.
Cons:
NA
AC500 + B300S Home Battery Backup
The all-new flexible and versatile BLUETTI AC500 + B300S Home Battery Backup ensures you can run all lights to appliances to its maximum potential 24*7. It's a 5000W pure sine wave inverter with a 10kW surge.
It is modular as it can go with 6×B300S (3,072Wh each) expansion battery packs, which can move it to 18,432Wh capacity. It boasts versatility with six-way charging with AC/Solar/Car/Generator/Lead-acid Battery/Dual Charing (AC/AC+Solar). Additionally, it's one to trust with an expandable capacity from 3,072Wh to 18,432Wh and the use of a LiFePO4 Battery.
It also has smart App control and 16 versatile outlets. Moreover, you can take it anywhere to power the appliance anytime. With great input and output, you can rely on it at any time.
Pros:
  • Great expandable features.
  • Smart App control.
Cons:
  • Four years warranty
BLUETTI AC200MAX + 1*B230 Home Battery Backup
The incredible BLUETTI AC200MAX + 1*B230 Home Battery Backup is a budget-friendly option that helps you power your household appliances. It's a 2,200W AC pure sine wave inverter, which is expandable to 144Wh with 2×B230 or 8,192Wh with 2×B300.
Moreover, it can be charged with AC/Solar/Car/Generator/Lead Battery/Dual AC/AC+Solar. With a whopping 2,048Wh Capacity, it's the best for powering all light to heavy appliances.
Moreover, LiFePO4 Battery and its smart app control make it reliable and convenient. It has a fast charging of 1400W Max with solar and AC adaptors. Furthermore, it has 16 outlets to power anything simultaneously without worry. With great input, output, and expandable features, it is the perfect companion for all your electrical needs.
Pros:
  • It's expandable.
  • It has 7 ways to recharge.
Cons:
  • Four-year warranty
BLUETTI EP500Pro
Price
US$9,999.00
US$2,999.00
US$4,999.00
US$4,799.00
US$2,675.00
Battery Capacity
9.9KWh~19.8KWh)
3,072Wh Capacity (Expandable w/ up to 4 × B300 for 12,288Wh)
5100Wh
3,072Wh to 18,432Wh
2,048Wh(Expandable Up To 6,144Wh
Power Output
Up to 9,000W
Up to 3,000W
Up to 3000W
Up to 5,000W
Up to 2,200W
10-year coverage
4-year
5-year
4-Year
4-year
How to Choose the Best Battery Backup for Your Home?
Here are some factors you must consider to choose the best home battery backup system:
Battery Capacity: The battery capacity is measured in kilowatt-hours (kWh). It's the amount of energy a system can store. So, it would be best to look at your present and future electricity needs and choose the most compatible one.
Power Output: The power output is ensured in watts (W). You should go with high-power output if you have many high-power products like heating and cooling equipment.
Your Budget: You should outline your budget and then look for the battery backup for your home with maximum features.
Lifespan: There is an estimated lifespan of the battery. You should discuss its time and continue with the one with a significant lifespan. Also, examine the warranties.
Brand: Your chosen brand must be reliable, flexible, and trustworthy. You can go through their online reviews. Also, the product must be modular, expandable, and durable. Moreover, ask for their customer support, installation methods, and post service support.
Why Do You Need to Invest in Home Battery Backup?
Here are some reasons why you may need to invest in battery backup for your home:
Uninterrupted Power Supply
Imagine that you have to attend an event today at 8 pm. You have a lot on your plate, like blow-drying your hair, straightening it, sending some files from your laptop, or preparing food for family members. All of these tasks may need electrical equipment in some way. In this scenario, if a blackout occurs, you may be unable to do all those tasks. In this situation, a home battery backup system ensures an uninterrupted power supply which is a blessing.
Cost Saving
You can store the power during the off-peak periods of energy demand. This lets you store energy and use it when the electricity demand is high, which may welcome huge bills. So, you can rely on the home battery backup system during high-power demand times.
Environmental Benefit
You are making your home and solutions more eco-friendly with an efficient battery backup for your home. Thye help you store the electricity from solar solutions or the grid, enabling you to reduce your carbon footprint. It not only means lower bills but also makes your home more environmentally friendly.
Return on Investment
A reliable home battery backup system means the constant supply of power 24*7. They are becoming popular with their long life, less maintenance, and durability. Also, if you have this system, the value of your house skyrockets. This is a great return on investment.
Energy security is essential for any home. A blackout can occur anytime with increasing power grid failure or other technical features. So, welcome peace of mind with a reliable home battery backup. It lets you have electricity and run appliances at any time. These are the most promising solutions that make your home energy-independent.
So, explore all the five new home battery backup solutions in 2024 and choose the most suitable for your home.
