The Best Solar Generators for Apartments for 2024
Solar Powered Generators
24/01/2024
With the advancement in solar technology, its use is not limited to big homes only. But apartments can also reap its benefits. Solar generators for apartments are compatible and efficient solutions to your everyday energy needs. They do not produce any toxic fumes, making their indoor installation easy.
However, there is still a vague understanding of their use and how to choose the best solar generator for an apartment that perfectly aligns with your requirements.
In this guide, we will cover the top 3 recommendations for apartment solar generators and answer all your related concerns, like how to choose one, which would be the best choice, and whether you can save on your electric costs.
Top 3 Solar Generators for Apartments in 2024
A new year always starts with new resolutions, and for this year, shifting your power needs to solar generators could be your best decision. However, with various options available, it's always difficult to choose one single unit that can fulfill all your power needs.
Thus, we have our recommendations for the top 3 solar generators for apartments in 2024. They are efficient, reliable, compatible, and, most importantly, cost-effective. The best part is that all the mentioned products come with a 4-year hassle-free warranty and lifetime custom support.
BLUETTI AC200P + 3*PV200
bluetti ac200p
Whether you want a backup for your apartment or a reliable power source for your off-grid adventures, BLUETTI AC200P can withstand all your energy needs.
The unit comes with a Lithium Iron Phosphate battery (LiFePO4) extending up to more than 10 years with one charge cycle per day. Its advanced Battery Management system ensures an optimum power supply to mitigate any risks for your voltage-sensitive devices.
What sets this product apart from its competitors is its charging speed. With multiple charging streams, including AC, solar, Generators, and AC+soalr, it can charge itself from 0-80% in only 45 minutes
Furthermore, regarding its compatibility, the AC200P can run multiple devices at the same time with its various AC, USB, DC, and RV ports. Its integration with a 15W wireless charger ensures that none of your devices is left out.
Below is a table explaining the efficiency of this solar generator with various devices.
Device
Watt Requirement
Running Time
Coffee Maker
1150W
1.5 Hrs
Electric Grill
1100W
1.5-2 Hrs
Air Conditioner
5000 BTU
1-4 Hrs
Car Fridge
70W
20 Hrs
CPAP
40W
30-40 Hrs
Specification
  • Output power: 2000W pure sine wave inverter
  • Surge power: 4800W
  • Battery Capacity: 2000Wh
  • Output ports: 17
  • Charging streams: 7
  • Max solar input: 700W
  • Max dual charging (Solar+AC) input: 1200W
BLUETTI AC200L+3*PV200
bluetti ac200l
If you need a one-in-all solution for all your household power needs, we have AC200L for you. In case you find its built-in battery capacity not suitable for your requirements, the system supports the addition of 2 additional B300 batteries, boosting its battery capacity to 8192Wh.
Exactly like AC200P, its charging speed is also groundbreaking. You will have your unit charged from 0-80%, only in 45. And again, its LiFePO4 battery with battery management system is the cherry on the top.
To further ensure you do not only rely on solar radiations, this unit has multiple charging streams and could also be charged through a lithium battery, car, and generator.
With a portable design, to make its operations smoother, it can also be operated through the BLUETTI smart app.
Here is a list of appliances you can support with BLUETTI AC200L.
Device
Watt Requirement
Running Time
Coffee Maker
1200 W
3.8 Hrs
Kettle
1500 W
3+ Hrs
Refrigerator
150 W
30+ Hrs
Colling Fan
60 W
70+ Hrs
CPAP
40 W
115+ Hrs
Laptop
100 W
46 Charges
Phone
15 W
300+ Charges
  • Output power: 2400W AC
  • Powerlifting mode: Upto 3600W
  • Battery Capacity: 2048Wh
  • AC input: 2400 W
  • Solar Input: 1200W
  • Charging streams: 6
  • Charge cycles: 3000+ (Life span of more than 10 years with one charge cycle per day)
BLUETTI EP500 + 3*PV200
The Last unit on our list is a giant in terms of power-generating capacity. This perfect combination of power and portability comes with 2 wheels and can support the power needs of your entire home, party, or off-grid family trip for a day or couple of days.
To ensure safety and easy operations, EP500 has a battery management system, microcomputer chip, and touch screen. This means you can upgrade or operate the system through an internet connection.
With its highly efficient solar panels, this unit can charge its batteries even in low light conditions. What’s the most promising about this unit is its life span of around 20+ years with one charge cycle per day.
There are 2 variables available for this unit depending on their output power. The EP500 has 2000W, and the EP500 pro has 3000W.
  • Charge cycles: 6000+
  • Battery Capacity: 5120Wh
  • Charging ports: 1 X 12v Cigarette lighter port, 1 X 1000W PD, 4USB, 2DC, 1RV, and 2 Wireless charging ports.
  • Recharging: Flexible
How to Choose Solar Generators for Apartments?
In the diverse market of solar generators, every brand claims to be the best. However, only claims do not convert the rubbles into rubies. Thus, a prudent approach is necessary to find a reliable unit.
Here are some important checks you need to consider while choosing a solar generator for your apartment.
The capacity of Battery
Solar generators only produce power during sunlight hours, is a fact. This necessitates the addition of a battery to your generator. However, when choosing a battery, 3 crucial points include its charge cycles, capacity, and type of battery should be LiFePO4.
Reliable brands like BLUETTI offer batteries with exceptional charge cycles and LiFePO4 battery type, testifying that you have zero carbon footprints. Also, there is a wide range of batteries available there. Depending on capacity, you can choose what suits you the most.
Power Output
Power output means the capacity of a solar generator to run multiple appliances simultaneously. For example, a 2000 W solar generator can support the electricity needs of 10 appliances, each with a 200W power requirement.
When choosing a solar generator, it's essential to understand your power consumption patterns first. Contemplate this and then opt for a system that can meet your requirements. Giving some power headway to your generator for effective operations is recommended, yet not necessary.
Output ports
The next thing to consider is the output ports. You see, each electrical device is different and requires its specific port to charge. Either it could be USB, DC, or AC. Make sure your unit is compatible with all your household devices.
BLUETTI solar generators are more recommended cases here. They not only come with the above-mentioned conventional ports but are also integrated with Lighter, RV, and wireless charging ports, making them a perfect unit for all your appliances.
Recharging Time
Solar generators do not use fossil fuels to generate power. Hence, their recharging through solar panels is their only power means, making their recharging time a crucial factor. Additionally, fast charging also ensures that you have an interrupted power supply.
CNET, a well-established website known for its solar reviews, has ranked BLUETTI solar generators to have the fastest charging speed amongst its competitors, which is around 80 minutes from 0-100%. So, definitely, these units could be your way to go.
Related articles: Solar Power Generator for Apartment Buying Guide 2024
How Much Is a Generator for a Small Apartment?
How to Choose the Best Generator for an Apartment?
What Size Generator Do I Need for an Apartment?
bluetti ac180
To put this simply, the size of the generator you need for your apartment is totally dependent on your personal power requirements which can be calculated in three easy steps that are listed below.
  • Step 1: Enlist all the appliances that you need to run through the solar generator. That could be anything from refrigerators to ACs and laptops to blenders. Now check the power requirements that would be available on their labels. In case they are in amps and volts, you can use the equation below to convert them into watts.
Amps X Volts = Watts
  • Step 2: Once you have checked their running power requirements, it's time to look for their surge power. This is power any appliance requires initially to start. For example, if the running power requirement of your oven is 100W, its surge power should be around 1000W.
  • Step 3: Now add up all the running watts to get your power requirements. You can use the device with the largest surge power as a threshold. Any solar generator that can fulfill these running and surge power requirements would be suitable for your apartment.
Can I Use a Solar Generator in an Apartment?
Yes, the questions regarding generator use in apartments are about space constraints, noise pollution, and toxic fumes.
Given these issues, solar generators are the perfect solution to all these concerns. They are portable and can easily installed, requiring very little space. Their operations are quiet and do not produce any toxic fumes. These factors, coupled with their low maintenance and cost efficiency, make solar generators the most effective power backups to be used in apartments.
Which Generator Is Best for Apartment?
Apartments are closed buildings, and there are always issues with space. So it's recommended to opt for a portable solar generator like the one offered by BLUETTI. They not only help you save space but are also easily portable, and their sleek designs could effectively enhance the beauty of your apartment interior.
Additionally, look for solar generators with panels that have high-efficiency ratings. They can help you produce more power while taking up only a little space.
Is Worth to Buy a Solar Generator for Apartments?
For multiple reasons, solar generators are definitely worth buying for apartments. First and foremost, they require only initial investment and do not come up with running costs. Furthermore, they are quite, easy to operate, portable, and do not produce any pollution. They could not only serve your apartment energy needs but could also be your reliable partners through off-grid endeavors.
Can a Solar Generator Save You Electric Costs?
Solar generators are good solutions to conventional grid energy. Their use is not limited to only as backup powers, but are also gaining popularity as full-time power solutions to effectively save energy bills.
However, it is crucial to understand your energy needs first and then opt for a unit that can produce and store enough energy to meet your day-to-day operations. Additionally, if you want to earn through solar generators, you can produce extra power to sell to conventional grids.
The use of solar generators in apartments is gaining popularity. However, it is essential to consider the efficiency and suitability of solar units for your personal needs while opting for any of them.
We have sorted out 3 best solar units from BLUETTI that could effectively serve your needs. Their range varies from medium-sized apartments to homes with high energy needs. By investing in them, you can ensure a sustainable and reliable power supply to your apartment.
