Solar vs. Standby Generator: Which Is Right for Your Home?
Since power outages are a menace you need to contend with, having a power backup is not an option. For this, you can choose between a solar and a standby option. While both provide electricity to run your devices, each is suited for specific uses. So which should you buy? Let’s find out.
Solar Generator (price, pros and cons)
bluetti solar powered generator
A solar generator is a combination of solar panels, a battery, a battery charger, and an inverter. Unlike conventional solar panels, solar generators come with portable solar panels, meaning you can use them in just about any place.
While used in most households, solar generators are popular with campers, hikers, and overlanders as a power backup solution. Unlike conventional generators, solar generators do not use fossil fuels. Instead, the solar panels convert sunlight into electricity.
Price
So, how much does an average generator cost? Well, a solar generator with a 1000W capacity can sell for up to $3,000. Of course, larger and more sophisticated options sell at a higher price. Depending on its features, a larger unit ranges from $5,000 to $15,000 which is the case with BLUETTI solar generators.
Pros
  • Clean energy
One main benefit of solar generators is the production of clean and sustainable energy. They utilize photovoltaic technology to convert sunlight into clean and stable electricity. This helps reduce carbon emissions hence conserving the environment.
  • Low maintenance
While the initial investment amount is higher than conventional standby generators, solar generators have a lower maintenance cost. It is because they lack moving parts and you don’t have to foot for fuel costs. Once installed, they require minimal inspection with sporadic cleaning.
  • Quiet operation
Unlike standby generators that are notoriously noisy, solar units operate silently. This is beneficial to neighborhoods that prohibit the use of gas or diesel generators. Their quiet operation allows for a more peaceful and pleasant experience.
  • Versatile
Solar generators are extremely versatile since you can use them at home, while camping, and in other settings. Whether you need to charge your devices during a power outage or when camping, these generators got you sorted. Furthermore, they are scalable, meaning you can add more solar panels and batteries for better energy efficiency.
Cons
  • High upfront cost
Solar generators require a higher initial investment than standby generators. An average gasoline generator costs around $1,000 while a basic solar generator costs $2,500. Fortunately, you’ll spend less on solar generators since they have minimal maintenance costs.
  • Limited power supply
The amount of power a solar generator produces depends on its size. So, if you buy a smaller unit, the power supply might not meet your demand. A medium-sized solar generator might not power your entire home. However, it will charge your devices for a short period of time.
  • Slow to recharge
Most solar generators can only be recharged when there's ample sunlight. And even then, most will take 6 to 9 hours to recharge. Worst still, this is the rating when conditions are conducive. If live in a place where conditions are poor, you might consider buying a generator with other ways of recharging.
Standby Generator (price, pros and cons)
standby generator
As the name suggests, it is a backup solution for residential and commercial applications. They require specialized installation, and in most states, should be 20 feet away from your house. They are an ideal option if your state experiences prolonged power outages.
Price
An average standby generator that can power your home costs between $6,000 and $11,000 with installation costs inclusive. Minus installation costs, a standby generator costs $3,000 to $6,000. Since an average American household uses 20kW to 30kW, a $6,000 unit would be what you are looking to buy.
Pros
  • Reliable source of power
Standby generators provide reliable electricity during power outages. A professional electrician can help you buy the most ideal size for your power needs. With the right generator size, you will have backup power until electricity is restored.
  • Automatic
Modern standby generators are equipped with a feature that detects a power outage automatically. It will then switch to backup power in milliseconds. This means you don’t have to manually turn on the power. Some generators are instantaneous and you’ll barely notice when the power goes off.
  • No need to refuel
Unlike traditional standby generators that require you to refuel during a prolonged power outage, modern units are connected to your existing fuel line. Whether you use a natural gas or liquid propane line, the generator will run efficiently. As such, you won’t need to go outside to refuel.
  • Safer option
With a standby generator, you won’t be putting your health in danger since you don’t have to go outside to refuel. In addition, it ensures critical appliances have minimal to zero downtime, meaning your food and medication won’t spoil.
Cons
  • Notoriously noisy
Standby generators are very noisy, particularly the larger units. It is because of the many moving parts that make up the unit. So, before installing a standby generator, we’d recommend consulting your residential and local laws.
  • Specialized installation
If your state permits the installation of standby generators, you’ll need the input of a certified technician. This is because installation requires advanced plumbing and electrical skills and you should not do it as a DIY project. Furthermore, local authorities must certify that the installation meets the local construction code.
  • High maintenance cost
Unlike solar generators which have a high initial cost, standby generators have a higher maintenance cost. They require regular maintenance. And this ought to be done by a professional electrician, meaning you’ll be footing a high maintenance bill. In addition, you’ll need to factor in the fuel costs.
Are Solar Generators Safer Than Standby Generators?
Yes, some common safety features of solar generators include a battery management system and a built-in charge controller. The battery management system (BMS) is used to monitor the battery, protect the battery, estimate how long the battery will run, and report the operational status of connected devices.
Advanced solar generators also come with built-in MPPT charge controllers. It is used to correct the current-voltage characteristics when recharging the batteries. It prevents overcharging bolstering the battery’s longevity and safety.
3 Top Solar Generators From BLUETTI
bluetti ac200max
If you are looking for optimal power flexibility, consider buying this solar generator. It can be expanded to produce up to 6,144Wh or 8,192Wh depending on the expansion batteries. With it, you can power your refrigerator for 10 hours or light your house for over 100 hours. And thanks to the 2,200W pure sine wave inverter, you can enjoy a stable supply of electricity.
The solar generator is portable, meaning you can travel with it to camping and hiking sites. What’s more? You can recharge it using your car, generator, lead-acid battery, and four other options. You also get an app for controlling and monitoring the generator. It can recharge within 3 to 20 hours depending on the source of power.
bluetti ac200p
Like most BLUETTI solar generators, it comes with an inverter for the production of stable and safe AC power. This option has a maximum capacity of 2,000Wh. Unfortunately, it is not expandable. This makes it an ideal option for small to medium homes. It also comes with seven ways to recharge it, ranging from lead-acid batteries to solar panels.
While not as powerful as other BLUETTI power stations, it can power your electric grill, coffee maker, or air conditioner. And if you are into wireless charging, this model has a 15W wireless charging pad, meaning you can charge your iPhone with ease. And for seamless control and monitoring, you get an intuitive LCD display. Some of its safety features include BMS and Smart Temperature Activated Fan.
bleutti ep500pro
Finally, you can get yourself this portable and movable power station. With rubberized wheels, you can transport it from room to room with ease. It has a touchscreen where you can monitor and control it with ease. Furthermore, you can control it using an app.
The model comes with a 3000W-rated inverter, ensuring you get ample electric power.
With 15 outlets, you can power different devices simultaneously. Like most BLUETTI devices, it comes with the Battery Management System feature for safer and more durable operation.
What Do You Need to Consider Buying a Home Generator?
Some of the most important aspects you need to consider when buying a home generator include the following:
  • Power requirements
The main aspect you need to consider when choosing a generator for your home is the amount of power you need. You can answer this question by listing all the appliances the generator will be powering.
Small appliances such as smartphones, laptops, and TVs, require less energy, meaning a small generator can provide you with ample power. For larger appliances with a high starting wattage, you’ll need a larger generator.
  • Source of fuel
If you’ll be using a conventional standby generator, you’ll need to consider its source of fuel. Ideally, there are three sources of fuel: natural gas, propane, and gasoline. Gasoline is the most common since it is readily available. Solar generators will only require ample sunlight to produce ample power.
  • Budget
The ideal generator will arguably depend on your budget. Large solar generators have a higher initial cost compared to conventional standby generators. Small, portable generators are cheaper but produce less energy
  • Extra features
You’d want to buy a generator that affords you convenience. This convenience comes in the form of extra features. You can consider features such as automatic start, smart control, electric start, multiple outlets, and low-oil shutoff.
Related articles: Back Up Power for Home: How to Choose Solar Generator?
How To Choose A Lithium Battery Solar Generator
How to Choose The Best Whole House Solar Generator?
Well, should you buy a solar or standby generator? If you want a unit that will automatically power your home during a power outage, consider buying a standby generator. On the other hand,  if you want clean and eco-friendly power production, a solar generator is your best option.
