A Guide To Using Small Solar Generators For Camping
Camping
03/04/2026
Camping is a fantastic opportunity to get away from the hive of activity of everyday life and enjoy the great outdoors.
But for those who want to bring along some modern comforts like lights, fans, and phone chargers, a small solar generator can be a great solution.
In this guide, we'll take a look at the benefits of using small solar generators for camping, what to consider when choosing one, and some tips for using them effectively.
4 Benefits of Using Small Solar Generators For Camping
using a solar generator on an rv camping trip
Using a small solar generator while camping comes with several benefits. Below we have taken the time to list some of those key advantages for you:
  1. Eco-Friendly: Solar generators are a clean and renewable source of energy, making them an eco-friendly choice for powering your camping equipment.
  2. Portability: Small solar generators are designed to be portable and easy to carry, so you can take them with you on all of your camping adventures.
  3. Quiet Operation: Unlike traditional generators, solar generators operate quietly, which means you can enjoy the peace and quiet of the great outdoors without any noisy interruptions.
  4. Cost-Effective: While the upfront cost of a solar generator may be higher than other portable power options, it can save you money in the long run since you won't have to pay for fuel or electricity.
Choosing The Right Solar Generator For Camping
bluetti solar generator for camping
When it comes to choosing a solar generator for camping, there are certain factors that you absolutely have to consider.
Not all solar generators are made equally.
Therefore, it is very important you understand the differences and thus make an informed decision when it comes to buying a small solar generator for your specific camping needs.
Power Output
A solar generator's power output is measured in watts. You'll want to make sure the generator you choose is capable of powering all of your camping equipment. Consider the wattage of your devices and choose a generator that can handle the load.
Battery Capacity
The battery capacity of a solar generator is measured in watt-hours, and it will determine how long you can run your devices before needing to recharge. Make sure you choose a solar generator with adequate battery capacity to meet your needs.
Weight and Portability
Since you'll be carrying your solar generator with you on your camping trip, it's important to choose one that is lightweight and easy to transport.
Charging Time
The charging time of a solar generator will vary depending on the size of the battery and the amount of sunlight available. Consider how long it will take to fully charge the generator and plan accordingly.
Using Your Solar Generator Effectively
Once you've chosen the right solar generator for your camping trip, there are a few tips that will help you use your device more efficiently.
Charge During the Day
To make sure your solar generator has enough power to meet your energy needs, make sure to charge it during the day when the sun is shining. This will ensure that it's fully charged and ready to use when you need it. You'll often find that you use your solar generator the most during the morning and evening (when you are not out and about exploring).
Position Your Solar Panel Properly
When setting up your solar panel, make sure it's positioned in a location that gets plenty of sunlight throughout the day. Avoid shading the panel with trees or other obstacles. Remember, the sun moves throughout the day, so make sure to angle your panel according to the suns trajectory.
Use Energy-Efficient Devices
To make the most of your solar generator's battery capacity, use energy-efficient devices that require less power to operate. This is not 100% necessary, but it will help you get the most out of your solar generator.
Monitor Battery Level
Monitor the battery level of your solar generator and make sure to recharge it when necessary. Many solar generators (such as all BLUETTI generators) come with built-in battery level indicators.
Plan Your Power Needs
Before heading out on your camping trip, make a list of all the devices you'll need to power and how much power they require. This will help you choose the right solar generator and plan accordingly. If you need some help doing this, take a look at this article here, it teaches you how to size a solar generator correctly.
Using a small solar generator for camping not only allows you to enjoy the modern conveniences of lights, fans, and phone chargers while in the great outdoors but also offers numerous unique benefits.
Solar generators are eco-friendly, providing a clean and renewable source of energy for your camping equipment. They are also designed to be portable and easy to carry, making them the perfect addition to any camping gear.
Additionally, solar generators operate quietly, allowing you to fully immerse yourself in the peace and quiet of nature without any interruptions. While the initial cost of a solar generator may be higher than other portable power options, it is a cost-effective choice in the long run since you won't have to pay for fuel or electricity.
By choosing a small solar generator for your camping needs, you're not only making a sustainable choice but also investing in a reliable and convenient power source for all of your outdoor adventures.
