Discover the best home solar panels
Whether you're looking for improvements to your lifestyle, achieving your goals for the environment, or just saving money on electricity bills by using renewable energy, home solar panels might be just what you're looking for.
In this article, we will recommend solar panels that are perfect for your home use.
For low-budget crowd
BLUETTI PV120 120W SOLAR PANEL
The BLUETTI PV120 120W SOLAR PANEL is a lightweight solar panel that is portable for use anywhere. For low-budget people, it’s a great choice. The BLUETTI PV120 120W PANEL is equivalent to 2x50W panels but weighs less than half that of that.
The BLUETTI panel is ideal for home use, small on-board battery charging, folding rack mount or backpack option for hiking, and general on-the-move mobile charging.
 The BLUETTI PV120 120W SOLAR PANEL is of top quality, efficient, and cost-effective design, with great output power to cost ratio. The BLUETTI PV120 120W SOLAR PANEL is not only beautifully sleek and clean.
For high-budget  crowd
The BLUETTI PV200 200W SOLAR PANEL is a powerful solar panel with very high peak power, high surge power, and great efficiency.
The BLUETTI PV200 200W SOLAR PANEL is backed by a legendary BLUETTI brand name and reputable brand.  It is also a portable and foldable solar panel that can be easily installed in small areas.
Compared with PV120 SOLAR PANEL, it is more efficient. You can get more power in less time. Correspondingly, PV200 SOALR PANEL price is higher than PV120 SOLAR PANEL, and it is more suitable for high-budget people.
The following are its detailed technical parameters:
TECHICINAL DETAILS
Peak power
200W
Voltage at max power
20V
Current at max power
10A
Dimension ( unfolded)
86.6*20.5inch/2200*520mm
Dimension ( folded)
20.7*20.5inch/525*520mm
For large capacity crowd
The BLUETTI AC200MAX POWER STATION+3*PV200 PANEL COMBO is another unique panel from BLUETTI. It is a very powerful and efficiency-based solar charging station.
Why it’s suitable who need large capacity people? The BLUETTI AC200MAX POWER PANEL stores the electricity generated by solar panels during the day and powering electric load during the night. AC200MAX POWER STATION has a capacity of 2048Wh and can run for several hours for your home appliances. Hence this is perfect solar power for home.
  • Coffer maker (2000W): 68~70 cups
  • Air-conditioner (8000btu): 3~7 hrs
  • CPAP (40W): 40+ hrs
  • Light (10W): 50+ Hrs
Benefits of Solar Power for Home
1. Reduce or eliminate energy bills: The biggest reason consumers are switching to solar is their previously high energy bills. This usually consists of monthly utility bills that run into thousands of dollars.
However, Installing a solar panel can help reduce these bills. Solar panels are commonly referred to as an all-around energy saver. The potential savings of these solar panels in reducing and eliminating bills can be quite significant. When you install a Solar Panel in your home, in addition, you get the device also. The long-run cost savings can be huge. It is not uncommon for businesses to install Solar Panels on their roofs to achieve savings.
2. Help the environment: Clean environment is a good thing. Solar panels create power only when there is sunlight and only at the amount of energy the panel is ordered to produce. The eco-friendly nature of solar panel systems is something that benefits the environment at large.
3. It serves as a good backup during a power outage: Because PV panels produce power when they are not really in use, they can provide backup power for your whole house when the regular grid goes down. Backups can be a lifesaver in the case of an emergency.
Pros and Cons of Solar Panels for Home
Pros of Solar Panel
People with solar panels in their property will pay less in monthly electricity bills and save more on future energy costs.
Your carbon footprint is reduced by using green energy.
Allows you to sell back any extra energy you create through net metering
Certain tax savings may be available to you.
Cons of Solar Panel
Installing and maintaining a solar system is still a costly endeavor.
During winter, you might not be able to save enough solar power
Every few years, parts of the system must be changed.
It's possible that certain tax benefits have expired or may soon expire, depending on the circumstances.
4 Main Factors Affecting Home Solar Panels Efficiency
Solar panels are made up of energy-producing cells called solar photovoltaic, or PV cells. Four factors affect the efficiency of your solar panels, including the amount of sunlight your home gets available, the type of inverter present in your system, the size/shape of your roof to cover. Finally, how well shaded it is.
Location, Angle, and Direction:
Solar panels may seem like a simple black box on your roof, but this is an oversimplification. Believe it or not, your solar panels pick up different amounts of sunlight in different areas. Each of your solar panels is angled to intercept varying levels of sunlight. These angles cause losses in the best direction for the solar panels to keep producing efficient energy. More experienced homeowners may be able to mod their panels and angle them in a way that allows them to produce a more efficient amount of energy. Then you can meet the majority of power demands from a solar panel system this way.
Roof Suitability:
When considering home solar panels for your roof, it is important to consider whether the roof is strong enough to support the weight of the solar system. Some roofs may not carry some of the weight of the integrated solar system, which would result in a roof collapse. To determine whether your roof is strong enough to support the weight of a solar panel system, you should ask around for a recommendation from a qualified solar expert.
Size of the Solar Panel System:
The size of the solar panels contributes to the efficiency of the solar panel. The panel cells come in all kinds of different shapes and sizes. The bigger the solar panel system, the more electricity is generated.
Maintenance:
The maintenance of solar panels is crucial in the long term. Firstly, when it comes to producing energy within a solar panel system, whichever system you choose, they work essentially by absorbing sunlight. Therefore they are subject to deterioration if the optimal conditions are not maintained. Secondly, they have to be frequently cleaned because dust can reduce the power output.
Q1: Are home solar panels worth it?
The tax incentive and high energy savings are worth taking advantage of if you reside in a location with high energy costs and a sufficient solar rating. You can afford the initial outlay for both the environment and your pocketbook.
Q2: Is it hard to maintain solar panels?
There is very little that has to be done to keep solar panels in good working order. To keep the sun's rays shining through, they need a basic cleaning to remove leaves, grime, and other debris.
Q3: Can I use solar panels when it rains?
Contrary to common assumptions, solar power systems continue to produce energy even when it is raining. As long as there is enough sunlight, solar panels generate power even when it rains or is cloudy. As a matter of truth, rain and clouds do not prevent visible light from passing through them.
