BLUETTI Top 5 Quiet Generators for House [2024]
Product Reviews
While a generator can keep your household powered during power interruptions, it comes with multiple implications, too, and noise is at the forefront of all that. A noisy generator is not just annoying; it can also have serious health implications.
According to a study conducted by the Occupational Safety and Health Administration, frequent or prolonged exposure to noise can cause hearing loss over time and make physiological disturbances more chronic – this is where quiet generators appear on the scene.
To help you find the best quiet generator for your house, we conducted extensive research and analyzed scores of products in BLUETTI. All these products are analyzed on various factors, such as capacity, wattage output, noise levels, running time, safety, and customer satisfaction.
So here are our top 5 considerations from BLUETTI for Quiet Solar Generators.
BLUETTI Top 5 Quiet Solar Generators for
BLUETTI is a top-rated brand worldwide for portable power supply solutions. Although all of their products are noise-free, below are our top five recommendations for the best quiet generator from BLUETTI.
BLUETTI EP900 + B500 Quiet Solar Generator
The BLUETTI EP900 + B500, rated at a whopping 9,000W, is a reliable UPS backup for on-demand use. Its initial capacity is 9,920Wh. But, in case your energy needs evolve our time, it can be expanded by adding up to two EP900 expansion modules to reach a total of 19,840Wh.
This output rate is ample enough to run your entire household without any hitch. With it, you don't need to worry about potential energy price hikes or unexpected power fallouts. Besides, any surplus renewable energy can be sold back to the grid.
In addition, the EP900 + B500 incorporates the most pioneering technology. It utilises LifePO4 batteries. Additionally, BLUETTI also provides an unprecedented 10-year warranty for this product.
BLUETTI EP800 + B500 Quiet Solar Generator
bluetti ep800
Rated at 7,600W output, the EP800 + B500  kicks in within 20 milliseconds as soon as the power shuts down. This is a fully scalable system; its initial capacity is 9,920Wh, which can be amplified to 19,840Wh by adding 4 B500 expansion modules.
Whether you want to live off the grid or indulge in sightseeing at remote locations, the EP800 + B500 offers 24/7 UPS backup. With it, you can relish in the best of both worlds – the comfort of modern life or the tranquillity of nature.
The BLUETTI EP800 + B500 can easily be paired with your current solar system or new panels. It uses AC coupling to operate with existing solar systems – this way, it can save you those additional labor costs associated with rooftop solar wiring. The EP800 + B500 also allows for direct connection with solar panels through DC coupling.
With the EP800 + B500, you can enjoy every moment with peace of mind; there is no need to worry about power outages and grid failures. All these things now belong to the past. In addition, the EP800 + B500 can be controlled with the BLUETTI app. With its intuitive control, you can monitor real-time energy consumption, switch between working modes, and perform OTA updates, all from the touch of your fingers, regardless of where you are.
BLUETTI AC500 + B300S Quiet Solar Generator
bluetti ac500
The BLUETTI AC500 + B300S is a modular solar power system for all your energy needs. It comes with a powerful 5,000W inverter, which can take up to 10kW surge – this way, the AC500 + B300S ensures all your devices work at their best.
The AC500 + B300S initially arrives with 3,072Wh capacity. But, it can be expanded to 18,432Wh with six B300S expansion modules – more than enough to run your house off-grid for up to six days. Additionally, the AC500 + B300S can be charged at any time. It can accept up to 8,000W input when plugged into both the wall outlet and solar panels.
The AC500 + B300S provides 24/7 UPS backup and can keep all your gadgets operational, like a gas generator. However, it is chemically more stable and safe enough to be utilized next to you. It won’t cause any thermal runaways. So, you can have moments of peace whether you're at home, pitching a tent, or traveling in your RV.
BLUETTI AC300 + B300 Quiet Solar Generator
bluetti ac300b300
The BLUETTI AC300 + B300 enables you to expand power at your will. It is 100% modular with an inceptive capacity of 3,072Wh. It can accept up to four B300 expansion modules (3,072Wh per pack) to accomplish a total of 12,288Wh.
It offers an AC output of 1,800W by default, which you can boost to 3,000W with the 30A charging cable. Its robust inverter can adjust the charging rate in accordance with your needs.
With the BLUETTI smart panel, the AC300 + B300 can be tied to your home grid. Furthermore, it can be fast-charged using the wall outlet and solar panels simultaneously at a blazing rate of 5,400W. All these things make it an exceptional choice for those looking for a round-the-clock UPS system.
BLUETTI AC200MAX + 1*B230 Quiet Solar Generator
bluetti ac200max
The last quiet generator on our list is BLUETTI AC200MAX. It features 2,048Wh LFP cells and a powerful, pure sine wave inverter, which can deliver continuous power of 2,200W (4,800W surge). It arrives with two expansion ports, which can welcome either two B300 units (3,072Wh per pack) or two B230 expansion modules (2,048 per pack).
In the bargain, the AC200MAX is a perfect UPS system that can be charged in any way you prefer. It can take up to 900W solar input and 500W through the adapter. You can even charge it using both solar and AC input. Other recharge options include dual AC, a car outlet, and a lead-acid battery.
The AC200MAX can fulfill all your power needs with its incomparable outlet versatility. For RV enthusiasts, it incorporates a 12V/30A super powerful DC outlet and a built-in NEMA TT-30 outlet as well.
Comparison of 5 Quiet Solar Generators for House
Generator
Output Power
Noise
EP900 + B500
9,920Wh to 19,840Wh
9,000W
10 Years
≤ 50dB (A)
EP800 + B500
9,920Wh to 19,840Wh
7,600W
10 Years
≤ 50dB (A)
AC500 + B300S
3,072Wh to 18,432Wh
5,000W
48 Months
≤ 50dB (A)
AC300 + B300
3,072Wh to 12,288Wh
3,000W
48 Months
≤ 50dB (A)
AC200MAX + 1*B300
2,048Wh to 8,192Wh
2,200W
48 Months
≤ 50dB (A)
How to Choose the Right Quiet Generator for Your House?
Choosing the right quiet generator for your house is not a piece of cake. It requires careful consideration of a number of things, such as:
Noise Level
The most important thing to consider when buying a quiet generator is its noise level. While generator brands often use the “quiet” or “silent” label in their marketing, most of the quietest systems will create between 50 to 65 dB at full power. BLUETTI generators excel in this respect; their noise level is often less than 50 dB. Keep in mind anything over 65 dB is loud and must be avoided.
Power Output
There is no point in being silent if the generator cannot provide substantial power for your home energy needs. Make sure to evaluate your power consumption history before you start exploring the market for a quiet generator. As a general thumb rule, small generators produce less noise. But we have also identified large generators with a maximum of 50 dB noise, such as BLUETTI EP900 + B500.
Running Time
Since the generator will be used to power your house during blackouts, knowing how long your quiet generator will run before recharging or refueling is also crucial. Time to run can significantly vary from one place to another; only you can know the length of blackouts in your area. In most cases, a generator with more runtime (twice the length of blackout) is better, so you have sufficient energy for mission-critical downtime.
Related article: How to Choose Quiet Generators for Home Use?
Can You Use a Quiet Generator to Power Your RV?
bluetti power station
Absolutely! An RV can be powered using a quiet generator. But, how long you can keep your appliances operational can vary based on your generator’s capacity, your power management, and the appliances you are using.
At a minimum, we recommend a 2,500-watt generator to power your RV’s essentials, such as a blender, microwave, and coffee maker, and small electronic devices, such as a mobile and laptop. In case you want to operate larger appliances, such as the AC and RV heaters, a 4,000-watt generator is recommended.
Related article: How to Choose the Best Solar Generator for RVs?
Can You Use a Quiet Generator to Power Your Electric Car?
The answer can differ based on the power output of your quiet generator. A quiet solar generator with at least 5kW power output is required to charge a single EV.
In case you want to charge two electric cars simultaneously, a large generator with an output of 10kW or more is recommended.
Make Your Decision
The market is replete with quiet solar generators, but we have narrowed down the choices to 5 top picks. The quiet generators listed above are highly efficient, easy to install, and can even be used on the go. Remember to check out for noise levels, desirable capacity, output power, and additional features. Also, consider your budget and buy the one that provides the maximum in your preset range.
