BLUETTI Best Solar Batteries Backup System for Home 2024
Product Reviews
12/05/2026
Installing a solar system in your home is one of the best life choices where the cost of electricity soars daily. Solar energy reduces your reliance on the grid system, thus significantly cutting the costs of electricity. Also, solar energy is good for the environment as it reduces carbon footprint. One way to maximize your solar energy is by using solar battery backup. Batteries store up energy for later use during power outages. In this article, I will guide you through the best LiFePO4 batteries for your home or RV and how to choose the suitable batteries. Keep reading!
BLUETTI Best Solar Batteries for Home 2024
Looking for an efficient solar battery to back up your solar system? The BLUETTI solar batteries are highly efficient, have a large storage capacity, and are durable. They significantly help in reducing your electricity bills and reliance on the grid system. Here are the BLUETTI solar batteries to consider to meet your energy needs.
1. BLUETTI EP900 + B500 Home Battery Backup
bluetti ep900
The P900 and the B500 can deliver up to 9,000W and 14,880Wh. They are a perfect power backup plan that adopts the LiFePO4 battery cells. The batteries have a longer life span, 4 to 6 times longer than lithium batteries. The battery system comes with a 10-year warranty.
Features
  1. Durability- The EP900 and B500 batteries are encased in a durable, waterproof, and damage-resistant aluminum alloy encasement. The EP900 has an IP65 rating and is resistant to dust and water splashes. It is equipped with BMS for preventing overcharging, short-circuits, and other possible risks.
  2. Versatile- The battery system is compatible with both AC and DC. The battery system can integrate with the existing grid system to keep your home powered in case of an outage.
  3. Uninterrupted Power Supply- The backup battery provides a stable power supply if fully charged. It takes less than 10 minutes to switch to off-grid mode. With BLUETTI EP900 + B500 Home Battery Backup, your appliances will stay powered for long.
  4. Outstanding Power Capabilities- The EP900 can power a household with its 9,000W power. It powers appliances with up to 240V. The system allows you to maximize your power needs up to 19.8kWh by customizing the batteries.
  5. Environmentally Friendly- The EP900 and B500 batteries are recharged by clean and renewable solar energy. Unlike traditional generators, the batteries do not emit toxic gasses or noise, making them environmentally friendly and suitable for homes and businesses.
2. BLUETTI AC300 + B300 | Home Battery Backup
bluetti ac300
The BLUETTI AC300 and B300 battery backup system is an excellent hybrid power station designed to meet your power needs off-grid. The battery hybrid system has two MPPT charge controllers with up to 2400W charge rate.
Features
  1. Expandable Power- The BLUETTI AC300 is a 100% expandable battery backup combining up to 4 B300 battery modules. It has a maximum power capacity of 12,288Wh, allowing you to power all your home appliances during emergencies or power outages.
  2. 2400W Solar Input- You can recharge the AC300 with up to 2,400-watt solar power.
  3. Reliable LiFePO4 Batteries- The system utilizes LiFePO4 batteries. They are known for their durability, efficiency, and security. LiFePO4 batteries have life cycles of 3,500+ to 80% or 6000+ to 50%. The incredibly long-lasting power station is a great investment in the long run.
  4. Multi-Recharge Outlets- You can recharge the AC300+B300 battery system with an AC outlet, solar panel, lead-acid battery, car, generator, or an EV station. However, the most sustainable way of charging the battery is via solar panels.
  5. UPS Backup- The battery system features a UPS system, which safeguards your PC and server from data damage or loss.
3. BLUETTI AC500 + B300S Home Battery Backup
bluetti ac500
The BLUETTI AC500 + B300S Home Battery Backup combo is versatile and highly efficient. The AC500 is the main battery with a capacity of up to 5000W continuous with a 1000W peak power. The B300S is an expansion LiFePO4 battery with a 3072Wh capacity. The AC500 depends on at least one B300S. However, it is capable of accommodating up to six B300S, a minimum power capacity of 3072Wh, and a maximum capacity of 18432Wh.
Features
  1. High Performance- The BLUETTI AC500 + B300S Home Battery backup can supply your household with enough power to run essential appliances. The system can charge a laptop and smartphone hundreds of times, run a standard-sized fridge for four days, and power an 1800W electric grill for at least 2 hours.
  2. UPS- The battery system has a UPS to ensure your devices stay powered and no data loss in case of an emergency power outage. The switchover is fast, so your essential devices, such as your laptop, will stay powered.
  3. LiFePO4 Batteries- This backup system utilizes long-lasting and highly- efficient LiFePO4 batteries with 3500 + cycles.
  1. LCD Display Screen- The system has a main LCD indicating the current input and loads.
4. BLUETTI AC200MAX + B230 Home Battery Backup
ac200max
The BLUETTI AC200MAX + B230 Home Battery Backup is a modular expansion system packed with 2048Wh LiFePO4 batteries, a total of 4096Wh capacity.
Features
  1. LiFePO4 Batteries – The battery backup system utilizes ultra-stable LiFePO4 batteries with 3500+ Life Cycles + 80% life cycles, which is five times more than the life of other batteries.
  2.  Maximum Power- The BLUETTI AC200MAX battery has an in-built 2200W AC inverter with 4800W surge plus a 1x 2048Wh on B230. With a powerful AC200MAX power station, you can power nearly all your basic home appliances and devices.
  1. Convenient Multiple Recharging- The AC200 MAX can recharge with up to 900W solar and 500W AC. Also, you can double charge with AC and solar for fast charging. Additionally, you can use the carport, solar panels, and AC to charge the B230.
  2. Several Outlets- Both batteries have several outlets, a total of 16+3. The AC200MAX has a NEMA TT-30 and one 30A super DC port suitable for RVs. The B230 has a 100W USB-A, USB-C, and a carport.
  3. Expandable Power- The AC200MAX has two expandable ports to accommodate two BLUETTI battery modules, the B230 with 2048Wh or 2x B300 with 3072Wh each. This boosts the total capacity to 8192Wh.
How Do Solar Batteries Work?
Solar batteries enable you to store excess solar energy for later use. But then, how do solar batteries work?
Solar batteries, especially the Lithium Ion, work through a chemical reaction. It stores the chemical energy and converts it into electrical energy. The chemical reaction occurs when the lithium ions release free electrons. These electrons flow from the negatively charged anode to the positively charged cathode.
The movement of the electrons from the anode to the cathode is made possible by the lithium-salt electrolyte, a liquid in the battery. It balances the reaction by providing positive ions. The free flow of electrons creates a current, which is now the electricity for powering appliances and lighting your home.
Pros and Cons of Solar Batteries
Pros
  1. 24/7 Energy Backup- With solar batteries, you will have a 24/7 backup in case of a blackout to keep the lights on and appliances powered.
  2. Saves on Electricity Costs- A major advantage of solar batteries is reducing the costs of electricity. You can recharge the batteries during the day and use the stored energy in the evenings, thus cutting down or eliminating the electricity bills.
  3. Environmental Friendly- Solar batteries are eco-friendly. They do not emit toxic fumes or noise. They are safe to use indoors, around children and animals.
  4. Durability- The most efficient solar batteries are the LiFePO4 batteries that last up to 10 years. Solar batteries are an ideal long-term investment, as you get to save costs on the recurrent electricity bills and the need to replace batteries every few years.
  5. Energy Independence- The solar system and efficient solar batteries allow you to gain energy independence from the on-grid system. You generate and store your energy for use even during cloudy days.
Cons
  1. High Installation Cost- The cost of solar system installation and purchase of solar batteries is high.
  2. Safety Concerns- Some of the solar batteries may cause safety concerns, especially if they overheat or if they are not installed correctly.
  3. Storage Capacity is Limited- The batteries have a storage capacity limit. Therefore, you need to constantly recharge them to access the solar energy all the time.
How Do I Choose a Solar Battery Backup?
battery
Solar batteries enable you to back up power during power outages and achieve energy independence. When choosing a solar battery, you should consider the following things:
1. The Solar Battery Capacity
The capacity of the solar battery is measured in kWh or kilowatt-hours. It is the amount of energy the battery can store. The storage capacity depends on the battery's chemical composition and the depth of discharge (DoD). The LiFePO4 batteries have a DoD of over 90%, thus a high capacity.
2. Life Cycle
A solar battery with a long cycle is durable and will serve for many years. The LiFePO4 batteries tend to have the best life cycle, averaging between 2,000 to 10,000 cycles.
3. Type of Battery
There are three types of solar batteries. The NMC (Nickel Manganese Cobalt), SLA (Sealed Lead Acid), and LFP (Lithium Iron Phosphate). The LFP batteries are safest, durable, eco-friendly, and highly efficient.
4. Battery Voltage
Low-voltage batteries have less than 100V voltage and provide lesser power. Batteries with over 400V are high voltage and have a faster charging rate.
5. Cost
Generally, the cost of purchasing solar batteries is high. The cost varies depending on factors such as capacity and voltage.
What Are the Different Types of Backup Batteries?
There are three types of solar batteries, namely lithium-ion, lead-acid, and nickel-cadmium.
Lithium-Ion
Lithium-ion backup batteries are highly efficient, durable, eco-friendly, and safe. Li-On batteries have good tolerance to high temperatures and have a life span of up to 10 years. They are superior compared to other battery types.
Nickel-Based Batteries
Nickel-based batteries have high energy density but a short life span and low tolerance to high temperatures.
Lead-Acid Batteries
Lead acid backup batteries are the most cost-effective. However, they have low energy density, short life span, and are heavy. Suitable for small-scale solar production.
Which Type of Battery Is Best for the Solar System?
The best batteries for your solar system are the LiFePO4 or Lithium Iron Phosphate batteries. LiFePO4 batteries have a long life span, high energy efficiency, safe and optimal performance.
In addition, LFP batteries have intricate thermal stability, which reduces instances of overheating that cause fire accidents. LiFePO4 batteries have life cycles ranging between 2,000 to 10,000 and can last up to 10 years. They are capable of withstanding frequent charge and discharge cycles.
Solar batteries improve the efficiency of your entire solar system by preserving the excess energy for later use. With solar batteries, you will run essential appliances and have lights on in case of power outages. Suitable solar batteries are a worthwhile long-term investment. It helps in cutting down the electricity costs and reduces over-reliance on fossil fuels, thus reducing the carbon footprint.
Consider features such as the cost, capacity, efficiency, and lifespan when buying solar batteries. The BLUETTI solar batteries and systems have a high degree of safety, are durable, and highly efficient. The BLUETTI LiFePO4 solar batteries enable you to maximize your solar panels, thus reducing your reliance on the on-grid system.
