3 Best Solar Generators To Buy in 2024
Product Reviews
26/12/2023
In this article, we provide the top 3 solar generators that are set to dominate the renewable energy landscape in 2024.
From compact and portable options to robust and high-capacity models, we've carefully curated a list of the best solar generators to help you make an informed choice.
\Join us as we explore the cutting-edge features, impressive performance, and eco-friendly benefits of these innovative solar power solutions. Get ready to embrace a greener future with the best solar generators of 2024.
Solar Generator
Surge Power
Weight
BLUETTI AC180
1152Wh 2,700W
35.27 lbs
5 years
BLUETTI AC500
3072W 10,000W
66.2 lbs
2 years
BLUETTI EB55
537Wh 1,400W
16.5 lbs
1 year
BLUETTI AC180
Ac180
The BLUETTI AC180 Portable Power Station is a versatile and compact power solution that brings convenience and reliability to your on-the-go lifestyle. With its impressive power capacity and comprehensive output options, this portable powerhouse is perfect for camping, outdoor activities, and emergency backup.
The AC180 boasts a robust 1152Wh (36Ah) LiFePO₄ (Lithium Iron Phosphate) battery, providing ample power to keep your devices running when needed. With over 3,500 life cycles to 80% original capacity and a shelf-life that requires recharging only every 3-6 months, you can rely on this power station for long-lasting performance.
Equipped with a pure sine wave inverter type and a surge power capability of 2,700W, the AC180 ensures stable and clean power delivery to your sensitive devices. It features four 120V/15A AC outlets, delivering a total power output of 1800W, allowing you to power multiple appliances simultaneously.
The power station also offers two USB-A ports with a combined power output of 15W and a USB-C port with a maximum power output of 100W. Additionally, it includes a 12V/10A regulated car outlet and a wireless charging pad with a maximum power output of 15W.
The AC180 offers multiple input options for convenient recharging. You can utilize the AC input with a maximum power of 1,440W or the solar input, supporting up to 500W (VOC 12-60VDC, 10A) for efficient charging using compatible solar panels (sold separately).
The car input allows for recharging from a vehicle's cigarette lighter port. The AC charging cable enables fast charging, taking only 1.3-1.8 hours for turbocharging at 1,440W, while solar panels can recharge the AC180 in 2.8-3.3 hours with a maximum output of 500W.
Designed with portability in mind, the AC180 weighs about 35.27 lbs (16kg) and features compact dimensions of 13.39" x 9.72" x 12.48" (340mm x 247mm x 317mm). It operates within an optimal temperature range of 20°C to 40°C (30°C to 40°C at 1500W Max.) and can be safely stored between -4°F and 104°F (-4°F and 104°F at 1500W Max.).
Indeed, the BLUETTI AC180 is certified to meet UL Standard, CEC, DOE, FCC, and CA Prop 65 regulations, ensuring its safety and quality. With an exceptional 5-year warranty, BLUETTI stands behind the durability and reliability of the AC180.
BLUETTI AC500
AC500
The BLUETTI AC500 is a portable power station that offers unrivaled power and versatility for all your energy needs. With a robust array of output options and an impressive capacity, this power station is ready to power your adventures, projects, and backup power requirements.
The AC500 features a remarkable range of AC outlets, including three 120V/20A outlets, one 120V/30A L14-30 outlet, one 120V/30A TT-30 outlet, and one 120V/50A NEMA14-50 outlet.
This total output of 5,000W ensures you have ample power for various devices and appliances. The pure sine wave inverter type guarantees clean and stable power, while the surge power capability of 10,000W handles high-demand situations effortlessly.
Charge your USB devices with ease using the AC500's USB ports. It offers two 5V/3A USB-A ports, two 18W USB-A ports, and two USB-C ports with a maximum power output of 100W each. Additionally, the power station provides regulated DC outlets, including one 12V/30A RV outlet and one 24V/10A car outlet.
The AC500 is designed for ultimate convenience and adaptability. It features a wireless charging pad that can accommodate two devices simultaneously, each with a maximum power output of 15W.
Recharging the AC500 is a breeze with multiple input options. You can use the AC charging cable input with a maximum power of 4,500W (with 1 B300S) or 5,000W (with 2 or more B300S). The solar input allows for a maximum input of 3,000W (VOC 12-150VDC, 15A), and the car input accepts 12/24V from a vehicle's cigarette lighter port. With AC and solar input combined, the maximum input capacity is 4,500W (with 1 B300S) or 8,000W (with 2 or more B300S).
Featuring a 240V split-phase bonding capability, the AC500 offers advanced power options for specific requirements. The power station can be controlled conveniently through the BLUETTI app, providing Wi-Fi and Bluetooth connectivity for seamless monitoring and control.
Despite its incredible power, the AC500 remains highly portable, weighing 66.2 lbs (30kg) and measuring 20.5 x 12.8 x 14.1 inches (52 x 32.5 x 35.8cm). It operates flawlessly within a temperature range of -4-104℉ (-20-40℃) and can be safely stored within the same temperature range.
Rest assured, the BLUETTI AC500 is certified to meet UL Standard, CEC, DOE, FCC, and CA Prop 65 regulations, guaranteeing its safety and quality. With an impressive 48-month warranty, BLUETTI stands behind the durability and reliability of the AC500.
BLUETTI EB55
EB55
The BLUETTI EB55 Portable Power Station is a compact and reliable power solution that is perfect for those on the go. With its impressive battery capacity of 537Wh (22.4V, 24Ah) and long lifespan of over 2,500 cycles to 80% original capacity, this power station ensures you have ample power for your devices.
Equipped with four AC outputs totaling 700W, the EB55 provides reliable and stable power for your appliances. The pure sine wave inverter type guarantees clean and consistent power output, while the surge power of 1,400W handles high-demand devices with ease.
Additionally, it offers convenient charging options with one USB-C port (100W max), four USB-A ports (5V/3A), and three 12V DC outlets (car outlet and DC5521 ports).
Recharging the EB55 is quick and efficient. With an AC adapter input of 200W, it can be fully recharged in approximately 3 hours. The solar input option allows for recharging in around 3 hours as well, provided ideal conditions of prime sunshine, proper orientation, and low temperature.
It can also be recharged through a 12V/24V car outlet or a combination of AC and solar inputs for even faster recharge times.
Weighing just 16.5lbs (7.5kg) and measuring at 10.94 x 7.87 x 7.79 inches (27.8 x 20 x 19.8cm), the EB55 is portable and easy to carry. It is designed to withstand various temperatures, with an operating range of -4-104℉ (-20-40℃) and a storage range of 14-113℉ (-10-45℃).
Safety and reliability are paramount, as evidenced by certifications from UL, CEC, DOE, FCC, and CA Prop 65. The EB55 also features pass-through charging capability, allowing you to charge the power station while simultaneously powering your devices.
With a 24-month warranty and BLUETTI's commitment to quality, the EB55 Portable Power Station is a trustworthy companion for all your power needs. Whether you're camping, traveling, or working remotely, the EB55 delivers reliable and convenient power, ensuring you stay connected wherever you are.
BLUETTI offers a range of portable power stations, including the AC500, AC180, and EB55, that provide reliable and versatile power solutions for various needs.
With their high-capacity batteries, multiple output options, and advanced features, these products are designed to meet the demands of outdoor enthusiasts, digital nomads, and those seeking backup power.
BLUETTI's commitment to quality and innovation ensures that their power stations deliver the performance and convenience required for a mobile lifestyle in 2024.
