2024 BLUETTI Whole House Solar Generator for Emergency Preparedness Review
A whole-house solar generator is a green and long-lasting solution to power your entire home. Unlike regular generators that use fossil fuels, solar generators harness the sun's energy, which is a clean and infinite power source. So, Make your home fully powered with the right-size solar generator.
If you're searching for a dependable whole-house solar generator for emergency preparedness in 2024, then read the whole review of different solar generators.
bluetti ep900
BLUETTI EP900 + B500 Home Battery Backup is one solution for all types of home energy needs. It features 9,000W power, which can run all 120V/240V devices to their maximum potential. Also, it has an expandable battery capacity ranging from 9,920Wh~19,840Wh with a B500 battery. The use of a durable and safe LiFePO₄ battery is amazing.
Another good aspect is that it can be installed outdoors or indoors(IP65 water-resistant) according to your requirements. It saves bills by selling extra energy to the grid. Moreover, it's compatible with existing or new solar panels or an electrical grid.
Pros:
  • It features ten years of warranty.
  • It's IP65 water-resistant.
  • Features monitoring with BLUETTI APP via WiFi or Bluetooth.
  • It can power all small to heavy appliances with great battery capacity and output.
Cons:
  • It may be a little heavy.
BLUETTI AC200P + PV200 Solar Generator Kit
bluetti ac200p
BLUETTI AC200P + 3*PV200 Solar Generator Kit is a whooping 2000W AC pure sine wave inverter having 2,000Wh capacity. It has a LiFePO4 battery with 3,500+ life cycles to 80%. Also, you can initiate fast charging with a solar + AC adapter simultaneously.
Plus, it can be recharged in seven ways like AC/Solar/Car/Generator/Lead battery/Dual AC/AC+Solar). It comes with 17 output ports having AC outlets, USB A and B, a wireless charging pad, DC output, and more for initiating simultaneous multiple charging. With so many flexible options and powerful battery capacity and output, it's best for home needs.
It comes with 200W Monocrystalline Silicon PV units which makes it a complete solution for home energy needs.
Pros:
  • It features recharging in seven ways.
  • There are 17 output ports for multiple charging.
  • It can be monitored with MPPT Charge Controller, BMS, etc.
  • It features four years of warranty.
BLUETTI AC200MAX + B230 + PV200 Solar Generator Kit
bluetti ac200maxb230
BLUETTI AC200MAX + 2*B230 + 3*PV200 Solar Generator Kit is a complete package for your home. It stores power like no other so that you can access electricity 24/7. It's a 2,200W AC pure sine wave inverter with a 2,048Wh capacity.
Also, you can increase its capacity according to your needs with 2×B230 to 6,144Wh or with 2×B300 to get 8,192Wh. Moreover, it features a LiFePO4 battery with 3,500+ life cycles to 80%, which means durability, safety, and longevity.
It can be recharged in seven ways (AC/Solar/Car/Generator/Lead Battery/Dual AC/AC+Solar). Also, it has a dual charging option via solar + AC adapter simultaneously. With 16 regulated output ports, you can power multiple devices that support AC, DC, USB A/C, or wireless charging pads.
Pros:
  • It comes with 2*B230 batteries and 3* 200W of solar panels.
  • It can be managed with an App, MPPT Controller, BMS, etc.
Cons:
  • NA
BLUETTI AC300 + B300
Portable Power Station
Check Discount
BLUETTI EP500 + PV200 Solar Generator Kit
bluetti ep500
BLUETTI EP500 + 3*PV200 Solar Generator Kit is a versatile power station with a 5100Wh capacity. It is a pure sine wave inverter with premium and safe LiFePo4 and has 2000W of output.
It's a movable power station so that you can relocate it anywhere. You can power as many devices as you like with different output ports. Also, You can recharge it via PV units and AC points. It has App controls and a smart touch screen for effortless monitoring.
Pros:
  • It's a movable power station.
  • It features five years of warranty.
  • The design is very stylish and modular.
Cons:
  • It's a little heavy
BLUETTI AC500 + B300S
bluetti ac500b300s
BLUETTI AC500 + B300S power system has a strong 5,000W power for regular use and can even handle a peak of 10,000W surge. You can expand it from 3,072Wh to a huge 18,432Wh capacity. The battery is made of LiFePO4 and can be charged up to 3,500 times to 80%. You can operate it utilizing a smart app through wifi or Bluetooth.
BLUETTI AC500 + B300S Home Battery Backup works on a 240V/10KW split phase system which means you can power all light to heavy devices with 2* AC500 units and 2* B300S units, reaching a max capacity of 36.8KWh.
You can recharge it in six ways  (AC/Solar/Car/Generator/Lead-acid Battery/Dual Charing (AC/AC+Solar). It has 16 outlets that work with 99% of devices. It's like an always-on backup for your home, giving you power 24/7. And it comes with a 4-year warranty.
Pros:
  • Its expanding power is incredible.
  • It's flexible with so many recharging options and output ports.
Cons:
  • NA
5 BLUETTI Whole House Solar Generator Comparison
Price Range
Battery
Power Output
Weight
BLUETTI EP900 + 2*B500 Home Battery Backup
US$10,298.00
10-year warranty
LiFePO battery with 9,920Wh~19,840Wh(expandable)
9,000W
441 lbs/200kg
US$2,499.00
4-year warranty
2000Wh LiFePO4 Battery
2000W
60.6 lbs (27.5kg)
US$5,144.00
4-year warranty
2,048Wh capacity with LiFePO4 battery
2,200W
61.9lbs (28.1kg)
US$4,896.00
5-year warranty
5100Wh with LiFePO4 battery
2000W
167 lbs (76kg )
US$4,799.00
4-year warranty
LiFePO4 battery with 3,072Wh to 18,432Wh
5,000W
66.2lbs (30kg)
How Does a Whole House Solar Generator Work?
Whole house solar generators are like your personal off-grid energy source, fuelled by the sun. They're a greener choice compared to generators that run on propane or gas.
Here's how they work: Solar generators combine solar panels, a charge controller, a battery, and an inverter. The battery holds onto the energy, the charge controller takes care of it, and the inverter changes it into usable electricity for your home.
People often use lithium-ion batteries because they're safer and better in the long run. Charge controllers make sure the battery is safe, and inverters turn the stored energy into power for your appliances.
Why You Should Get a Whole House Solar Generator?
A whole-house solar generator is a friendly way to power your home. It's different from regular generators that use fuels harmful to the environment. Solar generators use sunshine, which never runs out and doesn't hurt the Earth. When you choose this, you help keep our planet clean and healthy.
Also, this solar generator lets your home stay powered even when the regular power goes out. This is extra important if you live where there are storms or the power often stops working. With a solar generator, you don't have to worry about losing electricity, and everything stays calm.
Tips for Choosing the Best Whole House Solar Generator
bluetti solar generator
When you're picking the best whole-house solar generator, there are a few important things to think about. Let’s discuss these tips:
  • Check How Much Power and Energy You Need: Look at your past electricity bills to see how much power your house uses on average. This will help you choose the right one that gives you enough electricity. Always check the output in W and battery capacity in Wh.
  • Find Good Solar Panels: Some solar panels work better than others. Look for ones that can turn more sunlight into electricity and are made from the best materials like BLUETTI solar panels.
  • Think About Batteries: Solar generators have batteries that store the energy they make. Choose a generator with a big enough battery to keep your lights on when it's cloudy or at night.
  • Get a Good Inverter: The inverter changes the power from the solar panels into the kind your house uses. Make sure it's a good one that works well with your panels.
  • Plan for the Future: Maybe you'll need more power later. So, get a solar generator that you can add more panels to later if you want.
  • Know the Brand: Check what people say about the solar generator brand. If lots of people like it and it works well, that's a good sign just like BLUETTI.
  • Warranty and Help: A good solar generator comes with a warranty that tells you they'll fix it if something goes wrong. Also, ask if they help you if you need it.
  • Money Matters: Solar generators cost money at first, but they save you money on your electricity bill later.
  • Installation and Care: Some companies can help you put the solar generator in place. Ask them if they do that. Also, check how to take care of it so it works for a long time.
    • Thinking about these things will help you pick the right whole-house solar generator.
      To wrap up, whole-house solar generators are a better and more eco-friendly way to keep your home powered. If you choose a good one, like those made by BLUETTI, and look after it nicely, you'll have electricity all the time. Plus, you'll be doing your part to make the air cleaner by stopping pollution.
