Waterproof Hiking Backpack: The Ultimate Gear for Outdoor Adventures
If you're planning a hiking trip and gathering your gear together, one item you won’t want to forget is a decent backpack so you can easily get around with all your things.
Having the right one could make all the difference between a great hiking trip and one that turns to disaster. Having something like a waterproof hiking backpack, for instance, will protect you against the elements, survive in rugged and harsh environments and -- most importantly -- preserve all your essential gear.
Let's take a closer look at the advantages of a waterproof hiking backpack, including models that come with built-in portable power packs that will let you enjoy your trip all the more.
Why Choose a Waterproof Hiking Backpack?
When your hiking backpack is waterproof, you get a range of benefits over other backpacks that may not have the same features. They include:
  • Weather Protection: Your clothing and essential devices, such as your cell phone, laptop and possibly a GPS device, will be safe when it's raining or snowing.
  • Durability: A waterproof hiking backpack is typically made from strong materials that will allow it to deal with the most challenging of settings.
  • Versatility: You'll be able to use a waterproof hiking backpack for different activities and trips, from hiking to camping or just commuting.
Key Features of a Great Waterproof Hiking Backpack
When you have a hiking backpack that's waterproof, you'll not only ensure everything in it is dry but it's likely to have a sizable storage capacity that will let you take everything you need on your excursion.
Depending on the model, it may also have separate compartments that will let you organize your gear. This is also an important consideration when choosing a waterproof hiking backpack because it allows for:
  • Separate Spaces: You can keep clothing, electronics, first aid supplies and food and water in different areas of your backpack. This means you have easy access when you need them and don't have to go searching, or even empty your bag because they're at the bottom of it. It can also be critical if you need something like a flashlight in a hurry, if you're trekking in the dusk and you need to light the path.
  • Wet and Dry Items: A good waterproof hiking backpack will have areas for wet items like a damp towel or swimwear. This isolates them and prevents moisture from making dry clothes wet and potentially damaging sensitive electronics.
  • Better Weight Distribution: With compartments for different items, a waterproof hiking backpack generally allows for balanced weight distribution when it's on your back. The weight is distributed more evenly, making it easier to carry and resulting in less strain on you.
Powering Your Hiking Adventure
Many hikers take a portable power pack with them, so they can use lighting and appliances, and recharge their cell phones, laptops and GPS devices -- essential for communications and not getting lost when on remote trails.
The problem is that power packs can be bulky and take up far too much space in a backpack, meaning you either have to carry them in another bag or not take all your items with you, because there simply isn't the space.
A good solution is a travel-friendly waterproof hiking backpack with a small yet powerful powerpack integrated into the design. The BLUETTI Handsfree 1 Backpack Power Station, for instance, is a splash-resistant, all-in-one design with 42 liters of capacity that features solar charging so you can go completely off-grid and still power and charge your devices.
Caring for Your Waterproof Hiking Backpack
If you look after your waterproof hiking backpack properly, you'll get years of use from it. After every trip, make sure to empty it out and use a mild soap and water to clean the surfaces -- don't use an abrasive cleaner or rough cloth as they may damage the surface.
And examine your backpack carefully to see if there are any tears or other damage from your trips and have them either repaired or apply a waterproof coating. Then store it in a cool and dry place so it's ready for your next trip to the great outdoors.
Preparing for a hiking or trekking trip with a waterproof hiking backpack will go a long way toward protecting you and your valuables, letting you enjoy stunning scenes without any worries, or strain.
Are All Hiking Backpacks Waterproof?
Most backpacks are not waterproof, so your clothing and electronics risk getting damaged if it rains when you're hiking. Look for models that specifically say they are waterproof hiking backpacks.
What Is the Difference Between Hiking and Trekking Backpacks?
A hiking backpack is typically smaller than a trekking backpack. That’s because you usually will need more items with you when you go trekking over longer distances and periods. With hiking, you may only be gone from your campsite or other base for part of the day.
Do You Need a Special Backpack for Hiking?
Depending on your trip duration and where you'll be hiking -- in a forest, along a rugged mountain trail or anywhere else -- you'll need a suitable bag to carry everything. A waterproof hiking backpack can be essential no matter where you find yourself.
Is There a Difference Between Men's and Women's Hiking Backpacks?
Yes. Hiking backpacks for women are smaller, to account for a shorter torso. They usually have straps that are curved, to better accommodate the female chest.
How Big of a Backpack Do You Need for a Day Hike?
To take things you need for a day's hike, such as extra clothing, food and water and your electronics, aim for a hiking backpack that's between 20 and 30 liters.
