How To Choose The Best Camping Water Heater?
At home, you just switch on your geyser to take a hot shower and start doing your work. However, outside, and especially during camping, there is no such facility, except for a camping water heater. The device offers you similar comfort that a geyser provides. However, the water heater is available in many options in the market, which can confuse campers.
If you are going for a long outdoor trip, where you will be hiking or participating in other camping activities, and are unaware of how to choose the best camping water heater, then allow the blog to inform you about the essential factors before purchasing the heater. In this way, you will also have a better camping experience.
What Are The Different Types of Camping Water Heaters?
Before rushing to know the essential factors, you should know about the different types of camping water heaters. These exist in the following types:
Tankless Water Heater
A tankless camping water heater takes the lead in providing you with hot water whenever you feel the need to take a relaxing shower. The best part is that this tanker is lightweight and pretty compact, so it won’t trouble you while you are camping. But keep in mind that this water heater might let you down in terms of water flow rate, especially when temperatures drop. So, plan accordingly.
Tank-Style Water Heater
Tank-style water heater is another type of camping water heater. This heater has the ability to store a certain amount of hot water, so you can take multiple baths. As far as the price factor is concerned, this particular one is easy on your pockets but heavy to carry, which makes it lose the portability score. Therefore, proceed if you find it more beneficial according to your needs.
Primary Factors To Keep In Mind
Now that you know about the types, it's time to move on to the primary factors that you need to keep in mind. They are as follows:
Fuel Source
A camping water heater needs a fuel source to run on to offer you comfortable hot water. Therefore, you need to look into the kind of fuel the camping water heater uses. They are as follows:
Propane
A propane-powered camping water heater is appreciated for its versatility and the fact that it is pretty portable. You can use this heater in a variety of locations, including off-grid campsites. The drawback is that they demand a propane tank which has to be replaced or refiled to serve the purpose.
Electric
A camping water heater that runs on electricity is a simple solution and easy to handle. They can help you more in campgrounds, which have electrical hookups. Apart from this, an electric camping water heater can impress you more in terms of being energy-efficient, but the sad part is that they don't consist of propane-powered units.
Solar
A solar camping water heater has been spreading positive waves and attracting eco-conscious campers who try to do everything within sustainable boundaries. These turn out to be an ideal option for elongated camping or off-grid living. However, the issue in this case is that because they rely solely on sunlight, they might not work properly when it’s cloudy or if your camping area does not receive enough sunlight. Therefore, you can make the most out of Bluettii’s AC 180 and Elite 200 V2. These portable power solutions offer a battery capacity of 1152Wh and 2,073.6Wh and a solar charging port so you can enjoy your hot showers even when there is no proper sunlight.
Rate Of Water Flow
The rate of water is measured in gallons per minute (GPM) and plays a pivotal role in quickly heating the water so you can wash off your camping activities exhaustion through a hot shower. Keep in mind how many people will be with you on this camping trip or whether you are going solo. This will help you decide faster which camping water heater will be suitable for your showering needs and other camping tasks. The higher the flow rate, the better the results, but that may also demand a stronger camping water heater.
Range of Temperature
You must check the temperature range while getting a camping water heater, as that determines the extent to which the water can become hot. The good part is that the majority of similar heaters provide you with a temperature range which you can adjust according to your desired temperature. Therefore, purchase one while keeping your camping location and temperature in mind.
With this, we come to the end of the blog and hope that now you are clear about the types of camping water heaters and the essential factors such as fuel source, where you can charge your solar-powered camping water heater with the help of Bluettii’s portable power solutions, look into the water flow rate, and temperature range.
What is the best type of camping water heater?
The best type depends on your specific needs. Tankless water heaters are portable and provide instant hot water, while tank-style heaters offer a larger capacity but are less portable.
How much water can a camping water heater hold?
Tank-style water heaters have varying capacities, typically ranging from 5 to 10 gallons. Tankless water heaters don't store water but heat it on demand.
How long does it take to heat water in a camping water heater?
The heating time depends on the water heater's capacity, fuel source, and the desired temperature.
Is a camping water heater safe to use indoors?
Most camping water heaters are designed for outdoor use only. Using them indoors can be dangerous due to carbon monoxide poisoning.
How do I maintain my camping water heater?
Regular maintenance is essential for optimal performance and longevity. Clean the burner and other components as per the manufacturer's instructions.
