The future is now, and it's solar. With the rise of renewable energy sources like wind and solar, Texas has seen an increasing trend of people installing solar panels on their homes to reduce their carbon footprint.
But what if when there is no sun or wind? That's why solar generators in Texas are important!
These generators work with your existing power system to store electricity generated by renewable sources so you can use it whenever you need it.
Why Do You Need Solar Generators In Texas?
With extreme weather events like El Nino, hurricanes and wind storms becoming more frequent in Texas, the need for energy storage is greater than ever.
The good news is that solar generators can act as batteries that can store large amounts of electricity generated by solar panels so you don't have to worry about power outage anytime.
1. Texas Climate
Texas is known for its hot, humid summers and mild winters, which makes it perfect to harness solar energy.
Solar generators are a great way to reduce your carbon footprint while also being able to power up when there’s no sunlight or wind.
With the rise of renewable energy, solar generators are the future of energy storage.
2. Frequent Power Outages
One of the biggest benefits of solar generators is that they can help you easily deal with power outages.
According to recent reports, Texas has the worst track record for power outages in the entire country!
With millions of people living in areas prone to frequent blackouts, having a solar generator can be a life-saver.
3. Natural Disasters
In addition to frequent power outages, Texas is also prone to natural disasters like hurricanes and floods.
These events can often knock out power for extended periods, leaving people without the ability to cook or keep their food cold.
Solar generators can help you prepare for these types of emergencies by providing a backup source of electricity that you can rely on.
4. Full Sun
One of the most popular reasons why people in Texas install solar panels and generators is that they provide a free source of energy from the sun.
By using solar generators, you can tap into this abundant resource to store electricity generated during peak hours when demand is high or your existing power system goes down.
How to Choose a Solar Generator
If you're interested in making the switch to solar, it's important to choose a generator that can work with your existing power system and provide reliable backup electricity when you need it most.
The good news is many solar generator manufacturers offer models designed for both homes and businesses, so they can be plugged right into your current electrical setup without any modifications required.
1. Power Requirements
The next step is to determine how much power you will need the solar generator to provide. This can be done by multiplying your average daily energy needs by three to get a rough estimate of the amount of power.
2. Capacity
The amount of power your solar generator is called capacity, which should match the maximum wattage you calculated in step two. For example, different solar generators will be required for home use and camping respectively.
3. Expandability of Power
One of the best things about solar generators is that they can be expanded over time to accommodate increased energy demands.
So if you only need your solar generator occasionally, like powering a refrigerator or fan during blackouts, it may make sense to purchase the smaller one and upgrade it as necessary (which will reduce costs).
4. Brand
It's also important to choose a solar generator brand that is known for offering reliable products.
Since many companies are manufacturing solar generators, it can be difficult to determine which one offers the best features at the lowest price point.
Fortunately, you don't have to take our word for it - customer reviews found online are generally unbiased and provide insight into how satisfied they are with their purchases.
5. Portable
The portability of the solar generator is also of great importance while making a choice.
If you plan on using it only for short-term emergencies, a smaller and lighter model may be all you need.
However, if you're looking for a solar generator that can be used as a permanent backup power source, then you'll need a larger one, which can be easily transported from one location to another.
6. Recharge
One more thing to consider when choosing a solar generator is how long does it take to recharge.
Different models will require different amounts of time, so you may want to choose one with highly efficientfast charging capabilities if you plan on using your energy storage device frequently (which will reduce costs).
7. Outlets and Charging Ports
Another thing to consider when choosing a solar generator is what types of electrical outlets it's available.
For example, some models will provide multiple AC sockets while others are equipped with USB ports for charging your electronic devices.
Some Great Solar Generators in the Market Right Now
The BLUETTI solar generator is a portable device that can provide up to several hours of backup power for your home.
It has multiple AC sockets with high wattage and USB ports which you can charge phones, tablets, laptops, lights and more when needed.
It features quick charging which makes it perfect for those spontaneous picnics or camping plans.
So next time when you think about going off-grid, check out BLUETTI solar generator.
It also comes with a car charger so you can charge it on your way to the campsite.
This solar generator may have less capacity than other products in the market.
However you will also need to play less as the costs would be less as well.
BLUETTI AC200Max Power Station
The BLUETTI AC200 Max Power Station is a solar generator that can be used for both home and outdoor.
It is a very popular solar generator in Texas.
With a capacity of 2048Wh, it’s equipped with multiple AC sockets, USB ports, and LED lights.
What's great about this model is that it comes with solar panels. You can also install the product app to control and monitor the status of your solar generator.
The capacity of this solar generator can be further expanded. Its high price is due to high capacity as well as the high-quality solar panelsm.
You can even run an electric gill, air conditioner and refrigerator for hours with this solar generator.
Q: Is It Worth Going Solar In Texas?
It's important to remember that running a solar isn't a one-size-fits-all solution. In some cases, thanks to net metering agreements in Texas, you may be better off staying connected to the grid even if you have access to solar energy. However, if you live in a state like Texas and your home uses a lot of energy, solar may be the best option for you.
Q: Is Solar Generator A Good Investment?
Solar generators offer several benefits, including reducing your reliance on the grid and providing backup power during outages. A solar generator is a great investment. Not only are you going to save money on energy bills but you can also play your part in keeping the environment clean. They're also a good investment because they can be used to generate income by selling excess energy back to the grid through net metering agreements.
Q: What Is the Most Powerful Solar Generator?
The most powerful solar generator in the market right now is the Point Zero Energy Titan Solar Generator. The capacity is 2000 watt with a 3000 watt high efficiency inverter.
Q: Can solar generators run fridges?
It depends on the size of the solar panels and the capacity of the solar generators you have. If you wish to run your fridge on a solar generator only, it may be possible unless it has a reasonable capacity. However, you have to realize that if you are planning to power up other electronics on the same solar generator, it may be difficult to run your fridge.
When choosing a solar generator in Texas, it's important to take variety of factors into account including the brand reputation, size and charging time.
Additionally, you also need to think about what types of devices you need to power and whether or not the solar generator has the necessary outlets/charging ports.
If you're still unsure which solar generator is right for you, consider hiring an energy consultant.
