Your caravan must have a reliable power source to make your adventures fulfilling. The three primary sources are Petrol generators, Diesel generators, and Solar generators. But which one is the best for the caravan? We'll compare all these options and single out the best generator for your caravan.
You would never want to be out of power when off-road or camping in the woods. The generator's reliability is a significant concern. Besides that, the generator should be portable, easy to operate, and budget-friendly. Recently, parks have imposed restrictions on fuel-based generators. It also counts in the comparison.
Power is necessary; it has a defining impact on your caravanning experience. Most people take power generators for granted, which they regret later. It's better to make an informed decision when choosing a power source for your caravan. There are various options available to you; let's see how they compare.
Types of generator
There are three contenders: Petrol, Diesel, and Solar generators. Let's explore how they work and their usability for caravans.
Petrol Generators
Petrol generators have combustion engines that run on petrol. The petrol is burnt to produce a pressure effect that moves the alternator attached to the engine. The alternator produces electricity. Petrol generators come in various sizes and capacities. They are commonly used as power backup when the electricity supply is cut.
Portable petrol generators with a capacity ranging from 1500W to 2000W or more are used in caravans. These generators supply 240V AC power, but some have an added DC output option. The fuel consumption is different for different generator types. Ideally, a normal generator will consume 2-to-3 gallons of fuel to supply 2000W for up to 10 hours, depending on usage.
Petrol vs. Diesel
Comparatively, petrol generators are more efficient than diesel generators. They’re less noisy and require less maintenance. Given the fuel costs, petrol generators are also less expensive to operate. However, diesel generators are preferred over petrol generators for continuous power supply. Overall, petrol generators are better than diesel generators for caravans.
Petrol vs. Solar
When compared to solar generators, petrol generators have multiple leverages. They supply AC power. Unlike solar generators that depend on weather conditions, they can supply continuous power. The solar output is variable, whereas petrol generators provide a constant supply. If you're using petrol generators, you can park your caravan anywhere without looking out for the Sun.
Diesel Generators
Diesel generators also have a combustion engine that burns diesel to produce electricity. The diesel generators are based on an air compression mechanism, which creates the pressure effect. The alternator rotates inside the generator and produces AC power. Like petrol generators, diesel generators are categorized based on size and capacity.
The diesel generators used in caravans have 2000 – 2400W capacity. They're smaller, but portability is an issue in diesel generators. The additional accessories that optimize power output reduce the portability. A diesel generator consumes about one gallon of fuel to supply power for up to 3 hours, depending on usage.
Diesel vs. Petrol
Diesel generators have a unique advantage over petrol generators. The diesel engine efficiency is greater than the petrol engine efficiency. However, the higher fuel costs neutralize the difference. Many people prefer diesel generators for caravans for their durability. You can run a diesel generator for long hours without worrying about heat-up issues.
Diesel vs. Solar
Solar generators are incomparable to diesel generators except that you don't need to worry about the Sun using a diesel generator. Moreover, solar generators' initial cost is higher than diesel generators. Otherwise, both generators have their merits and demerits.
Solar Generator
Solar generators are a contemporary technology. They're extensively used in caravans and proven to be effective. Most modern caravans have solar generator kits that effectively fulfill the user's power needs. A solar generator kit uses three core elements: solar panels, a power station, and battery backup.
The solar panel captures the Sun's energy, then it's supplied through the power station, and excess energy is stored in the battery for later use. You can design a solar generator kit based on your power needs. It mainly depends on the number of solar panels and required battery backup.
Solar vs. Petrol & Diesel
Solar generator kit is highly portable, lightweight, and compact compared to other generator types. It is highly sustainable and doesn't require any carbon fuels to run. The power quality is optimized using advanced converters. You get constant AC/DC output without fluctuations. Although initial setup costs are high, there are no operational costs like other generators.
The solar generator provides you with clean energy. There's no need for maintenance or fuel source. It's just like plug-and-play. You can stay completely off-grid for days using solar generator kits. It's by far the best power source for caravans.
Comparing Petrol, Diesel, and Solar Generator
Sno. |
Characteristics |
Solar |
Petrol |
Diesel |
1. |
Caravan Compatibility |
High |
Moderate |
Moderate |
2. |
Operating Costs |
None |
High |
High |
3. |
Noise and Emissions |
None |
Moderate |
High |
4. |
Maintenance |
Low |
High |
High |
5. |
Price |
High |
Moderate |
Moderate |
6. |
Output (Max.) |
18000 Watts |
2200 Watts |
2200 Watts |
7. |
Life |
10-20 years |
5-10 years |
5-10 years |
Electricity Demand Analysis for Caravan
Let’s assume a mid-sized caravan for electricity demand analysis. Such a caravan can easily host three 350W solar panels. The consumption will depend on the electric equipment and appliances. For instance, the caravan has:
- 12V lighting: 5*20W = 100W
- Water Pump: 1*24W = 24W
- 12V TV: 1*120W = 120W
- Energy-efficient Fridge: 1*160W = 160W
- Air Conditioning: 1*1000W = 1000W
- Appliances (Laptop, Coffee Maker, Phone Chargers, etc.): 1*300W = 300W
The total power consumption of a mid-sized caravan would be between 1500W to 2000W. You can easily power your caravan by installing three 350W solar panels with a 200 ah battery backup.
BLUETTI is providing well-designed solar generator kits for caravans. If your power needs range between 1500W to 2000W, you should get a BLUETTI AC300 + B300 + PV350 panels kit . It is a complete package that can fulfill all your power needs. If you get it installed, you can plan a week-long trip. It enables you to go into extreme wilderness and still get sustainable power.
The highlights of this kit include a multi-recharge facility. You can charge it with any other power source if the solar output is insufficient. The system also supports fast recharge; you won't need to wait longer for power. Plus, you can control the kit through your smartphone. It offers you accessibility and convenience.
The BLUETTI PV350 Solar Panel that come with the kit are specifically designed for caravans. They're foldable and made from water-resistant material. You no longer need to worry about the panels driving in the rain. And if you're on rough terrain, you can fold and pack them. The panel's efficiency is also high; it captures every bit of the energy.
How to Choose the Best Generator for Your Caravan?
If you're hunting for a generator for the caravan, there are a few things to remember. Here's how you can choose the best generator for your caravan:
- Power Needs: Calculate the total power consumption of your caravan in watts. Keep in mind excess usage, and then choose a generator.
- Fuel Availability & Storage: If you're going for a diesel or petrol generator, ensure the fuel is readily available. Besides that, fuel storage can also be a problem as it poses multiple hazards.
- Portability: Caravans have limited space, so choose a portable option. Weight can also be a problem when moving or operating the generator.
- Costs: Both initial and operation costs should be considered when choosing a generator. Selecting an option that is more viable in the long run is better.
Why Do We Recommend Solar Generators More?
Caravans are designed for convenient and peaceful camping adventures. Both diesel and petrol generators are noisy options with hectic operation. You will need to source the fuel and fill it occasionally. The noise from generators will ruin the peace of your campsite; ultimately, you won't be able to enjoy your time.
Here are all the reasons why we recommend solar generators more:
- Solar generators are noiseless and clean energy sources.
- They are maintenance-free and require little or no intervention to operate.
- The campsite restriction doesn't apply to solar generators.
- The portability and lightweight make them easy to carry and store.
- Solar generators are best compatible with caravans.
You should invest soundly and buy a solar generator instead of diesel or petrol generators. BLUETTI is offering you top-end products at market-competitive prices. So, end your quest and buy a BLUETTI product for your caravan. The smart BLUETTI AC180 Portable Power Station is best for mid-size caravans.
It is fast recharging, with a whopping 1800W capacity. You can charge it with solar power or from your caravan's generator. It is completely noiseless and highly portable. The device won't take up more space than a shoe box. If you're going to the lake, you can carry it with you. Sounds convenient? It is also controlled with a mobile app.
Solar generators are a better, more sustainable, and more reliable alternative to petrol and diesel generators. It's not about which is better but about which is viable today. Go green, and go for solar generators!
The world is adopting sustainable power resources; petrol and diesel generators are obsolete. You look for fresh, natural spots when you go up the mountains or deep into the wilderness. How come you take a polluting generator with you? It's not in line with your social responsibility.
