Solar Panel Size & Weight: A Comprehensive Guide
Have you ever wondered how big solar panels are?
Solar panel size range in a variety of sizes, factors such as solar cell type, total wattage and the type of panel all affect the overall size.
solar panel array power sun electricity
In this article we are going to lay down the foundation and give you all the factors that dictate solar panel size & weight.
Additionally, we have created tables which give you examples of solar panel size based on wattage and solar cell type.
How Big Are Standard Solar Panels?
Standard residential solar panels, the ones you would have installed onto your homes roof, measure on average 65 inches by 39 inches, or 5.4 feet by 3.25 feet, covering an area of 15 square feet.
There are slight measurement variations depending on the solar panel’s manufacturer.
For large scale solar installations like the ones built onto warehouses you could expect solar panels to measure up to 6 feet (these are known as commercial solar panels).
To understand solar panel size, you need to first understand the general makeup of the panel.
Solar panels are made up of smaller individual solar photovoltaic (PV) cells. PV cells always come in the same standard size:156 mm by 156 mm, which is approximately 6 inches long and 6 inches wide.
The majority of small scale solar installations, like the ones you are likely to get on your home, are made up of 60 solar cells.
Commercial solar installations on the other hand, are made up of 72 cells, and can go up to 98 cells or more.
Solar panel size - residential and commercial panels
FEATURE
RESIDENTIAL PANELS
COMMERCIAL PANELS
Average Length (inches)
65
78
# of Solar Cells
60
72
Average Width (inches)
39
39
Average Depth (inches)
1.5 - 2
1.5 - 2
Essentially, the number of cells found in a solar panel is directly responsible for its length.
See below a comparison of residential panels VS commercial panels:
how big are solar panels
Most setups, whether residential or commercial usually do not comprise of a singular solar panel.
So what sort of measurements are we looking at with a full blown solar installation, say something like a 10 kW solar system?
Let’s assume you use 34 average sized solar panels each with a 300 watt power rating and stack them up vertically next to one another making two rows of 17 panels each.
Your 10 kW solar system will measure 55,25 feet by 10.8 feet, covering a total of 596 square feet.
Of course, these overall measurements assume that you place each said panel closely next to one another, leaving minimal space in between each panel.
In reality however, you will need factor in slightly more area, as you need to take into consideration the unique shape/orientation of your roof.
What is the Average Area of a Single Solar Panel?
solar panel area
A good example of common residential solar panel would be the High Density Shingle PERC Module (HiDM) from Canadian Solar.
This single solar panel is capable of producing 345 watts of power (weather dependent).
The said solar panel dimensions are as follows: 1700 ˣ 992 ˣ 35 mm (66.9 ˣ 39.1 ˣ 1.38 in)
To work out the total area we want to multiply the length by the width.
However, to not end up with an incredibly large measurement, we will want to convert mm into feet.
  • 1700 mm = 5.5 feet
  • 992 mm = 3.2 feet
Therefore, the average area of a modern single solar panel measures 17,6 square feet.
What Factors Determine Solar Panel Size?
When it comes to the factors that determine solar panel size, you need to consider the following criteria:
  • Solar panel type
  • Solar panel wattage
  • Solar panel material
Solar Panel Type
As you may well be aware by now, solar panels come in 3 main different types: monocrystalline, polycrystalline and thin-film.
Each one of these different types have their own unique advantages/disadvantages.
Here is a quick table to give you a basic understanding of the differences:
Monocrystalline
  • High efficiency
  • Aesthetics
  • Higher costs
Polycrystalline
  • Low cost
  • Lower efficiency/performance
Thin-film
  • Portable/flexible
  • Lightweight
  • Aesthetics
  • Lowest efficiency/performance
Solar panel type dictates size because of the different materials used inside each of them.
For example, monocrystalline and polycrystalline both use cells made of silicon wafers.
However, the composition of silicon in each type of solar panel varies.
Monocrystalline solar cells are always cut from a single, pure crystal of silicon.
Whereas polycrystalline solar cells are made up of smaller fragments of silicon crystals (which are melted together in a mould before being cut into sheets of wafers).
This difference in composition/makeup of the solar cells themself create slight inefficiencies.
In this case, monocrystalline solar panels are more efficient than polycrystalline solar panels and because of this vary in size.
Take for example two solar panels capable of producing the exact same wattage (take note of the difference in size):
Monocrystalline solar panel dimensions & weight – 365 watt
  • Dimensions: 1776 mm × 1052mm × 35mm.Area = 5.82 x 3,45 = 20,07 square feet
  • Weight: 45 pounds
Polycrystalline solar panel dimensions & weight – 365 watt
  • Dimensions: 2000 mm x 992 mm x 35 mm. Area = 6.56 x 3,25 = 21,32 square feet
  • Weight: 49 pounds
Clearly solar panel type has an affect (albeit small in the case of mono vs poly) on the overall size of the solar panel, the more efficient the makeup, the less big the actual panel needs to be.
Solar panel wattage
Solar panels are made up of series of single solar cells, all of which are connected in parallel circuits to form the entire solar panel.
Of course, the higher the solar panel wattage, the more solar cells it needs to achieve that rating. So ultimately, the more wattage a solar panel produces, the more solar cells it will require. Thus, the bigger the overall panel size. Additionally, the size of the solar panel also depends on the amount of power you actually need - such as from your home appliances, for example, televisions, fridges, washing machines, vacuum cleaners, air conditioners, etc. And you would need to know how much power they consume per day.
Are Solar Panels Too Heavy for A Roof?
are solar panels too heavy for a roof
Let us assume you are installing an average residential solar system on to your roof.
The average weight of a 365 watt monocrystalline solar panel is 45 pounds.
To establish a 10 kW system you will need a total of 28 solar panels mounted on top of your roof.
We know that one 365 watt solar panel weighs 45 pounds and takes up an area of 20,7 square feet.
Therefore, 28 solar panels will take up an area of 580 square feet and will weigh a total of 1260 pounds.
1260 pounds ÷ by 580 square feet = 2.17 pounds per square foot. When you take into account mounting equipment, you can raise the weight per square foot to about 3.5 pounds.
This means a 10 kW solar system (with mounting equipment) will weigh 3.5 pound per square feet.
A modern roof with concrete or clay tiles should be able to support 27 pounds per square foot.
As you can see by these calculations, a 10 kW solar system should have little to no affect on your homes roof, that is, your roof is strong enough to support some of the biggest types of solar panels.
(Please note, our advice should not take the place of a professional solar installation company.)
Here's another video: What would happen if all the houses were covered with solar panels?
How Much Weight Do Solar Panels Add to a Roof?
This all depends on what sort of solar system you are looking to install onto your roof.
Let us assume you want to install a 5 kW, 10 kW or 15 kW solar system onto your residential home.
First things first, you need to distinguish hoe many watts make up a kW.
The calculation is easy, 1000 watts makes 1 kW. Therefore, you simply have to times the kW by 1000 to figure out the total wattage.
  • 5 kW = 5000 watt
  • 10 kW = 10,000 watt
  • 15 kW = 15,000 watt
To understand how much weight solar panels add to our roof, we need to decide on what wattage solar panel we want to install. The average residential solar panel produce 300 - 420 watts.
For this example let us use a 365 watt solar panel, we already know that they weigh about 45 pounds per panel.
The calculation is as follows: 5000 watt ÷ by 365 watt panel means you will need 14x 365 watt solar panels to make a 5 kW system 14 solar panels x 45 pounds = 630 pounds.
  • 5 kW solar system will add 630 pounds to your roof.
  • 10 kW solar system will add 1,260 pounds to your roof.
  • 15 kW solar system will add 1,845 pounds to your roof.
(Please note, these amounts do not include mounting equipment.
Examples of Solar Panel Sizes
 Average size of solar panels
FEATURE
RESIDENTIAL PANELS
COMMERCIAL PANELS
# of Solar Cells
60
72
65
78
39
39
1.5 - 2
1.5 - 2
Average weight of different solar panel manufacturers
SOLAR PANEL MANUFACTURER
SOLAR PANEL WEIGHT (60-CELL RESIDENTIAL PANELS)
SolarWorld
40 - 47 lbs
Canadian Solar
40 - 51 lbs
Hanwha Q CELLS
41 lbs
Trina
41 - 50 lbs
SunPower
33 - 41 lbs
Renewsys
39 lbs
Axitec
39 - 41 lbs
Kyocera
42 - 44 lbs
Enersol
39 lbs
After reading this article we hope you have a much better understanding of average solar panel size, weight and dimensions.
Many manufactures around the world are spending tons of money on exploring different ways to increase the power and efficiency of solar cells.
There is no doubt that the future holds many advancements in this green technology, and Bluetti Power is on the forefront of that innovation.
1. What is the size of a solar panel?
about 65 inches by 39 inches
Typical residential solar panel dimensions today are about 65 inches by 39 inches, or 5.4 feet by 3.25 feet, with some variation among manufacturers. SunPower panels are 61.3 inches by 41.2 inches.
2. What is the weight of a standard solar panel?
On average, standard solar panels weighs 18KG. The weight varies sightly depending on the brand's manufacturer. Any roof in good condition can handle this weight.
3. How much does a 300 watt solar panel weigh?
They generally consist of 60 or 72 solar cells (or 120-144 half-cut solar cells) and can produce 300 to 400 watts of power. In general, residential solar panels can weigh as low as 35 lbs (kg) and as high as 50 lbs (in kg). On average, most residential solar panels weigh around 40 lbs.
