3 Best Emergency Solar Generators For Your Home
30/05/2023
According to the U.S. Energy Information Administration (EIA),
customers throughout the states experienced over eight hours of electric power interruptions in 2020 and in 2021, just over seven
But that is just the average for the entire country. On average, states such as Louisiana experienced over eighty hours of power outages.
Most of these blackouts are caused by extreme weather events such as hurricanes, wildfires, and winter storms.
All these events can destroy power lines or disrupt electricity generation, and depending on the severity of the cause, damage can take hours to be repaired.
Extreme weather events that result in widespread blackouts do occur. Take the tornado outbreak that moved across the USA from Texas to Maine, for example. This disaster left 6.8 million people without an electrical supply.
Or take the longest blackout in U.S. history, for example, caused by Hurricane Maria in 2017. This extreme weather event left hundreds of thousands of people in Puerto Rico and the U.S. Virgin Islands without power for more than 100 days!
The point we are trying to make is that emergencies do happen. And when they do, you should come prepared.
This article highlights the 3 best emergency solar generators equipped to supply you with enough power to get through any power outage.
How Much Electricity Do You Need?
In any emergency scenario, there is a hierarchy of needs that will need attending to. For example, safety should be your primary cause of focus. After that things such as food and water need to be attended to.
This article doesn't touch base on these things. It assumes you have made the necessary preparations for any potential emergency scenario and are now looking to finalize your energy solution during such an event.
If you are looking to learn how you should prepare for an emergency situation such as a hurricane passing through your state, we recommend you read Ready.Gov
When it comes to the amount of energy required during an emergency event, it all comes down to your individual needs.
In order to help you decide on which emergency solar generator is best equipped for your needs, we need to calculate how much electricity you would require during a power outrage.
Grab a pen and paper and make a list like the one below:
Appliance Wattage Run Time (Hours) Wh
Refrigerator 200 10 2000
LED Lights x 5 25 10 250
Electric Grill 1000 1 1000
Rechargeable Flashlight 10 10 100
Handheld Radio 10 10 100
Total 1245 W N/A 3,450 Wh
Now, what have we done above?
Well it is pretty simple, we have created a list of the appliance we would like powered during a power. Next we have jotted down their individual power draw or wattage. This can usually be found on a label on the back of the appliance.
Next, we have jotted down how long we would like each of these appliances to run. Finally, we multiplied the wattage by the run time to figure out how much energy capacity would be required to power all these appliances for said time.
(Please note that refrigerators are generally rated at more than 200 watts. However, you must consider that they cycle on and off throughout the day as opposed to running continuously. Simply divide your refrigerators total wattage by 3 to get a more accurate indicator of its power requirements.)
Our energy requirements is a total of 3,450 Wh.
This means that we will need to insure our chosen solar generator has the same or (ideally) greater energy capacity.
Below we highlight the 3 best emergency solar generators you can buy at BLUETTI.
AC200 MAX + B300
bluetti-ac200max-b300
First up we have the popular BLUETTI AC200 MAX. This is one of our smaller emergency solar generators, with a standard energy capacity of 2,048 Wh.
As you would note from our table above, this would not be sufficient energy capacity to meet our demands.
However, the AC200 MAX allows for external battery pack connection. By connecting the two B300's you will increase the energy capacity up to 8,192 Wh.
Shop the AC200 MAX Kit Here
  • Capacity: 2,048Wh (51.2V, 40Ah)
  • Type: LiFePO4 (Lithium Iron Phosphate)
  • Life Cycles: 3,500+ Cycles to 80% Original Capacity
  • Shelf-life: Recharge to 80% Every 3-6 Months
  • Management System: MPPT Controller, BMS, etc
  • AC Outlets: 4 x 120V/20A Outlets 1 x 120V/30A NEMA TT-30 2200W In Total
  • Inverter Type: Pure Sine Wave
  • Surge Power: 4800W
  • USB-C Port: 1 x 100W Max.
  • USB-A Port: 2 x 5V/3A USB-A 2 x 18W USB-A
  • 12V DC Outlets: 1 x 12V/30A (RV Outlet) 1 x 12V/10A (Car Outlet) 2 x 12V/10A DC 5521 (5.5mm Outlet) *All Regulated.
  • Wireless Charging Pad: 2 x 15W Max. (For Each)
  • AC Adapter Input:
  • 500W.
  • Solar Input:
  • 900W Max., VOC 10-145VDC, 15A
  • Car Input:
  • 12/24V from Cigarette Lighter Port
  • Max Input:
  • 1,400W, with AC+Solar Input
  • AC Adapter (400W):
  • ≈5.5~6 Hours
  • Solar (900W):
  • ≈3~3.5 Hours (With prime sunshine, ideal orientation and low temperature)
  • 12V/24V Car Outlet (100W/200W):
  • ≈10 or 20 Hours
  • AC Adapter + Solar (1300W):
  • ≈2.0~2.5 Hours (With prime sunshine, ideal orientation and low temperature)
  • Dual AC Adapters (800W):
  • ≈3~3.5 Hours (Extra adapter is REQUIRED)
  • Weight: 61.9lbs (28.1kg)
  • Dimensions (LxWxD): 16.5 x 11 x 15.2in ( 42 x 28 x 38.65cm)
  • Operating Temperature: -4-104℉ (-20-40℃)
  • Storage Temperature: 14-113℉ (-10-45℃)
  • Certifications: UL Standard, CEC, DOE, FCC, CA Prop 65
  • Warranty: 48 Months
EP500 Pro
How to use the EP500
The EP500 Pro is one of the first emergency home backup power stations that we released. As is, it comes with a whopping 5,100 Wh of energy capacity. That's over double the AC200 MAX.
The EP500 Pro is best for those who are only looking to power the most important household items during a power outage emergency.
Again, if you refer to the table we created above, you will notice that 5100 Wh is more than enough to power our essential items for an extended period of time.
Shop The EP500 Pro Here
General Information
  • AC Rated Power: 3000W 3000W<load<3750W,2min 3750W<load<4500W, 5s 4500W<load<6000W, 500ms (peak 6000W)
  • Net Weight: ≈83kg (182lbs)
  • Dimensions: 500*300*760mm (22.8*11.8*29.9in)
  • Battery Capacity: 5100Wh
  • Battery Cell Type: LiFePO4
  • Rated Life Cycle: 3500+ Cycles to 80% Capacity
  • Charge Temperature: 0°C ~ 40°C (32°F ~104°F)
  • Storage Ambient Temperature: 0°C ~ 45°C (32°F ~113°F)
  • Working Environment humidity: 10-90%
  • Warranty Period: 60 Months
Input Specs
AC Input: 3000W Max
PV Input or T500 Input: 2400W Max 12-150VDC,12Ax2 12V/24V,8.2A
Output Specs
  • USB-C: 2*100W
  • AC: 100-120VAC*5
  • USB-A: 2*Quick Charging, 36W Total, 2*5VDC, 3A Total
  • Cigarette Lighter: 1*12VDC, 10A
  • RV (Aviation Port): 1*12VDC, 30A
  • DC 5521: 2*12VDC, 10A Total
  • Wireless Charging Pad: 2*5/7.5/10/15W
AC300 + X4 B300
bluetti-ac300
The AC300 is one of the most versatile emergency solar generators on the market today. By nature, this model is entirely modular. Meaning in order to store energy, you will need to connect external B300 battery packs to the AC300. Standalone, the AC300 is not able to store any energy.
At first glance you are probably asking yourself why we would build such a machine.
Well the answer is simple, it has massive energy storage capabilities. At full power, the AC300 connected to x4 B300 battery packs has an energy capacity of 12,228 Wh!
If we were to build a machine of this capacity as one unit, it would be incredibly hard to manoeuvre around.
Shop The AC300 Here
  • AC Outlets: 6 x 120V/20A Outlets 1 x 120V/30A TT-30 3,000W In Total
  • Surge Power: 6000W
  • 12V* DC Outlets: 1 x 12V/30A (RV Outlet) 1 x 24V/10A (Car Outlet) *All Regulated.
  • AC Charging Cable Input: 3,000W Max.
  • Solar Input: 2,400W Max., VOC 12-150VDC, 12A
  • Car Input: 12/24V from Cigarette Lighter Port
  • Maximum Input: 5,400W, with AC and Solar Input Simultaneously
  • 240V Split Phase Bonding: Yes
  • App Control: Yes, Wifi&Bluetooth
  • Scalability: Expandable W/Up to 4 x B300
  • Simultaneous Recharge & Discharge: Yes
  • Weight: 47.6lbs (21.6kg)
  • Dimensions (LxWxD): 20.5 x 12.5 x 14.1in ( 52 x 32 x 35.80cm)
  • Storage Temperature: -4-104℉ (-20-40℃)
  • Warranty: 48 Months (Enter to learn more about our warranty policy)
