Portable power stations are an excellent backup power solution. Lightweight and compact, they are ideal for car use since you can transport them with ease. Whether you are a camper, overlander, or live in an RV, a portable power station is a must-have.
It provides electricity in times of emergency and you can use it to charge your devices and run small devices. Here are some of the best options you can use in your car.
BLUETTI Best Portable Power Station Used in a Car
The BLUETTI AC240 Portable power station is a compact yet high-performance unit for your car. Coming with industry-standard features such as a built-in app, it affords you value for your money. It also has a large capacity so you can use it during those long road trips. And since it is compact, transporting it does not require excessive space.
Design: As mentioned, the BLUETTI AC240 Portable Power Station comes in a lightweight and compact design. Weighing 33 kg, it is easy to carry and with a slim design, you can place it in your car’s trunk. It also comes with an LCD display allowing you to monitor and adjust settings. There are several ports so you can charge multiple devices simultaneously.
Performance: While a compact power station, the BLUETTI AC240 has a capacity of 1536Wh, meaning it stores enough power for all your needs. What’s more? It has a 2,400W AC output ideal for charging and powering most common devices. And thanks to the IP65 rating it can withstand water and dust, making it a suitable option for outdoor activities.
Battery capacity: Like other BLUETTI power stations, it has a LiFePO4 battery, providing more capacity and performance. And if you want more power, you can connect 4 B210 batteries to expand its capacity up to 10,136Wh. With fast charging capability, it charges from 0 to 80% within 45 minutes. You don’t need to wait for hours to use it in your car.
Value for money: The BLUETTI AC240 is no doubt a worthy investment. Not only is it affordable, but also has a long lifespan. You’ll have recouped your investment within the first few years.
The BLUETTI AC200L Portbale Power Station is yet another unit you can use in your car. A compact and lightweight option, it comes with features that any car portable power station should have. From a long lifespan to multiple charging options, this is the power station to use during your road trips.
Design: Like other premium power stations, it comes with an intuitive LCD display for easier monitoring of settings. It also has a tactile power button to turn it on and off with ease. The front panel has numerous ports for connecting devices and charging devices. The black finish makes it an appealing unit. On each side of the power station are ergonomic handles for easier transportation. The lightweight design (28.3Kg) is also impressive.
Performance: The BLUETTI AC200L Portable Power Station doesn’t disappoint when it comes to performance. The unit has a 2,400AC output ideal for powering most devices in your car. And the impressive 3,600W Power LIfting Mode ensures you can connect larger appliances such as a refrigerator. With a 2,048Wh capacity, you will have ample power to run your devices for days. Another impressive aspect is you can recharge it using 6 ways. For example, you can use solar, AC, or lead battery, to mention but a few.
Battery capacity: As you’d expect, the BLUETTI AC200L has an impressive battery life. As an LiFePO4 battery, it can last for a decade or more while offering exceptional performance. If you connect it to a 2,400W AC power source, it can recharge from 0 to 80% within 45 minutes.
Value for money: While not a cheap unit, you get performance and features that will bolster your convenience. If you want a compact, lightweight, and high-capacity power station, consider buying this unit.
If you want a power station for simple power needs, the BLUETTI AC180 makes the cut. A minimalistic unit, it comes with features ideal for everyday use. And thanks to the provided app, monitoring and adjusting settings will be a piece of cake.
Design: Like other BLUETTI portable power stations, it comes in a compact design. Thanks to the LiFePO4 battery, it holds just the right capacity in a small package. And it is not bulky, weighing 35.3lbs. In fact, you can place it in tight spaces and still provide ample performance. You get tactile buttons, an LCD display, and several ports.
Performance: The performance in this power station is quite impressive. You get a capacity of 1,152Wh, which is ideal for powering small to medium devices. And thanks to the LiFePO4 battery, you’ll enjoy more than 3,500 cycles. This equates to a decade of use with no maintenance needed. The built-in pure sine wave inverter allows you to connect any device to the power station.
Battery capacity: Well, the battery capacity as mentioned is 1,152Wh, ideal for use in your car. You can use an MPPT or BMS management system to keep the battery working in good condition.
Value for money: Like other BLUETTI portable power stations, you get value for your money, given the features you’ll get in this model.
BLUETTI AC60 Portable Power Station
Sometimes you want a battery backup for simple power needs. For example, charging your laptop, smartphone, or even flashlights. For this, you don’t need a large power station, and the BLUETTI AC60 is the perfect option for you.
Design: BLUETTI AC60 is a portable power station weighing 20.1lbs, coming in a short and slender design. This model is extremely compact and it can fit in just any tight space. There’s an ergonomic handle to ease transportation and an LCD display to enable precise monitoring. As you’d expect, the buttons are tactile and the ports have sturdy covers to protect them from dust and water.
Performance: While not a high-performance unit, it has a 600W output rating and a 1200W lifting power. This means you can connect small to medium devices and still enjoy uninterrupted power supply. Another impressive feature is that it charges fully in one hour. And the best part is you can recharge it while using it. While you can use the LCD display to control it, there’s an app for remote monitoring and settings adjustment.
Battery capacity: This compact power station comes with an LiFePO4 battery, which provides better performance and requires no maintenance. Its modular design allows you to pair it with two B80P or B80 batteries for added capacity.
Value for money: The BLUETTI AC60 is a cheaper unit, ideal for people on a budget. But don’t let the price tag fool you. This unit provides ample power to keep your devices running.
BLUETTI EB3A Portable Power Station
Finally, you can get the cheaper and more compact BLUETTI EB3A power station. It comes with features and capacity ideal for simple usage.
Design: As you’d expect, the BLUETTI EB3A is not the most fancy of power stations. In fact, it comes in a minimalist design, having fewer buttons and ports. While rightly so, you get just about any button and port you’d need for your car use. Since it is a strip-down version, it is lighter and more compact, weighing 10.1lbs.
Performance: The unit has a 268Wh capacity, making it ideal for charging or running small appliances. That said, it can run a mini fridge for up to 3 hours or charge your phone up to 15 times. As you can see, you still get convenience larger power stations would afford you.
Battery capacity: It has a smaller LiFePO4 battery with up to 2500 cycles. With a 268Wh capacity, you are sure to keep your devices running for days.
Value for money: While a cheaper option, the BLUETTI EB3A power station provides value for money given the features it packs in a compact packaging. This is in fact a perfect option for people on a budget.
Benefits of Having a Portable Power Station in a Car
Having a portable power station in your car comes with many benefits. For example, you’ll have a reliable source of power when overlanding or camping. Unpredictable circumstances such as getting stuck at night or your car having mechanical problems can cause major disruptions.
Having a portable power station can help you have a dependable source of power. It can keep your devices and small appliances running as you wait for help.
A portable power station in your car makes outdoor activities more convenient. You don’t have to worry about your smartphone or outdoor gear running out of power. Just plug them into the portable power station and you are sorted.
Advantages of BLUETTI Portable Power Station
For one, BLUETTI portable power stations are of high-quality. They can withstand outdoor abuse, high temperatures, and weather elements. This means you can use them for outdoor and indoor activities. And since they are high-quality, you don’t have to worry about overheating, short circuits, or abruptly loss of performance.
Another advantage is they are compact and lightweight. This makes them ideal for outdoor activities and allows you to carry them from room to room. The power stations are also easy to use. For one, they have an intuitive LCD display. Secondly, they have tactile buttons, and come with built-in apps for remote control.
Well, if you want a high-quality power station for your car, consider buying any of the above models. Their performance, ease of use, and long lifespans will bolster your road trips and outdoor activities.
