If you are a resident of Florida, then it is important to inquire about the recent TECO power outage to ensure that you are not left in the dark. Knowing the purpose and benefits of the outage can help you and your family prepare for any future outages and know what to expect. Additionally, understanding the cause of the outage and steps that TECO is taking to prevent further outages can give you peace of mind and help you make informed decisions about your energy usage.
TECO Power Outage Map
What is TECO Energy?
TECO Energy, Inc. is a S&P 500 utility holding company headquartered in Tampa, FL. Founded over a hundred years ago, the company is the top producer of solar energy per customer in the state of Florida and is a subsidiary of Emera Inc., a geographically diverse energy and services company based in Halifax, Nova Scotia, Canada.With 99.98% service reliability, TECO Energy is committed to working in favor of the environment, social causes and being a good corporate citizen.
TECO Power Outage Map in Florida August 2023
Most of the major power companies in Florida have outage maps and they are usually updated regularly.The data below is extracted from TECO Energy’s official website.
TECO Power Outage Map:
County |
Customers Tracked |
Customers Out |
Probable Cause |
Status |
Hernando |
0 |
0 |
Functional |
Hillsborough |
672,297 |
2,756 |
Equipment Failure |
Crew is dispatched (enroute) to event |
Manatee |
0 |
0 |
Functional |
Pasco |
25,044 |
33 |
Tree Damage |
Pinellas |
11,146 |
54 |
Equipment Failure |
Multiple outages |
Polk |
89,084 |
73 |
Storm Damage |
Multiple outages |
Unknown |
0 |
0 |
Functional |
Tampa Electric is currently experiencing power outages in several counties in Florida. Individuals experiencing outages in Hernando, Hillsborough, Manatee, Pasco, Pinellas, and Polk counties may be affected. As of July 20th, 2021, there were 797,571 customers tracked with 2,829 customers out of power.
The cause of the outages are mainly due to equipment failure and tree damage. It is important to note that in Hillsborough and Pinellas counties, there are multiple outages due to storm damage. Tampa Electric crews are currently dispatched and enroute to the event. The estimated time for the power to be restored is not yet known. If you are currently experiencing a power outage, there are certain tips you can follow to keep you safe and comfortable: If you need to report a power outage to Tampa Electric, you can do so in several ways. You can call TECO's emergency line 24/7 at 1-877-588-1010. You can also report an outage online on the TECO website. Additionally, you can use the TECO Power Tracker app on your mobile phone to report an outage. If you are using the app, simply tap the "Report an Outage" button to get started. Finally, you can also report an outage by texting “OUT” to 35069. If you are experiencing a power outage in your area, the best course of action is to contact Tampa Electric as soon as possible. You can call TECO's emergency line 24/7 at 1-877-588-1010. You can also report an outage online on the TECO website or use the TECO Power Tracker app on your mobile phone to report an outage. If you are using the app, simply tap the "Report an Outage" button to get started. Additionally, you can also report an outage by texting “OUT” to 35069. The emergency number for TECO Electric Tampa is 1-877-588-1010. This number is available 24/7 and is the best way to report a power outage or other emergency services request. You can also report an outage online on the TECO website or use the TECO Power Tracker app on your mobile phone to report an outage. If you are using the app, simply tap the "Report an Outage" button to get started. Additionally, you can also report an outage by texting “OUT” to 35069. The best way to find out when your power will be restored is to contact your local power provider. Depending on the size of the outage and the extent of the damage, power providers are usually able to provide an estimated timeline for restoration. If there is an outage map available, you can usually get an idea of how long the estimated restoration time will be. For smaller outages, it's usually much quicker than larger outages. If you are still unsure, your local power provider should be able to give you an estimated timeline for power restoration. Outage maps are usually updated in real-time, so you should be able to get an up-to-date picture of the current power outages in your area. However, the accuracy of the data can vary depending on how often the power provider updates the map. Generally, most outage maps should be updated at least hourly, if not more frequently. If the outage map isn't updated regularly, you may need to contact your local power provider directly to get more accurate information about the duration of the outage in your area. Yes, there are other ways to find out about outages in your neighborhood. You can check local news outlets for updates, or even use social media to keep up with power outages in your area. Additionally, if you subscribe to a power provider's notification system, you may be able to get automated updates sent to your phone or email about outages in your specific area. Finally, if you know someone in the area who has power, you can investigate the outages yourself by driving around the neighborhood to see which areas are affected. https://outage.tecoenergy.com/ This map automatically refreshes every 15 minutes to ensure the information most recently entered by individual electric cooperative is reflected. Customers can enter an address, city or ZIP code at https://www.tampaelectric.com/poweroutages/ to find out if there are any power outages currently affecting an area. If a customer is currently experiencing an outage, he or she can access the TECO Power Outage Map via a battery-powered laptop with Internet connection, most smart phones and Internet devices, or by asking a friend or family member to go online from another location. If you’re looking for a reliable solution to frequent power outages, BLUETTI products are worth considering. BLUETTI’s AC500+B300S Home Battery Backup System provides 5,000W of rated power – enough to power your home and many other devices – and it even offers up to 18,432Wh of expandable capacity. It is a great way to stay connected to unlimited energy wherever you are. The battery is made of LiFePO4, which offers up to 3,500 life cycles to 80%. The system also provides 16 versatile outlets to fit 99% of all devices, and it even features 24/7 UPS Home Backup to ensure that you’re never without electricity. Additionally, the BLUETTI product is modular, meaning it’s simple to set up and customize according to your specific needs. It can be used with AC/solar/car/generator/lead-acid battery/dual charging, and it is capable of running 240V appliances with ease. All in all, the BLUETTI AC500+B300S Home Battery Backup System is a great way to ensure that you won’t be left in the dark if you experience frequent power outages. It is a reliable, efficient, and cost-effective solution that will help you stay connected to unlimited energy wherever you are. Did your lights just go out? Please allow up to 10 minutes for your outage to appear on the map, or use the phone numbers below to report it to TECO Energy Company. Outages impacting less than 10 customers will not be displayed. Power Outage Near Me: Power Outage Las Vegas, Plano Power Outage, Power Outage San Marcos
The Cause of the Outage
Recovery Time
Tips for Power Outage Users
Q1: How do I report a power outage Tampa Electric?
Q2: Who to contact if no electricity in my area?
Q3: What is the emergency number for TECO Electric Tampa?
Q4: How can I tell when my power will be restored?
Q5: How often is the outage map updated?
Q6: Is there another way I can find out about outages in my neighborhood?
Power Restoration Time
BLUETTI: Whole-Home Battery Backup Power
Current Outages
