Power Banks for Camping: Essential Portable Power Solutions
Heading off on a camping adventure doesn't mean disconnecting from the electrical grid and communications, as long as you take a power bank along with you. That way, you can run lighting and your appliances as well as charging cell phones and laptops so you never run out of battery power.
A power bank for camping purposes is also vital when you're on the road and need to know where you are at all times. A handheld GPS device will pinpoint your location with accuracy as well as guiding you along the way -- as long as you keep it charged.
Let’s take a deeper look at power banks for camping and what you should consider if you're thinking of getting one.
Features of Power Banks for Camping
Power banks for camping -- also known as portable power packs or plants -- come in different sizes and capacities. The first thing to do when looking at various units is to see what their capacity is and if they fit your power needs. You'll need 10,000mAh for cell phones, for example, or 20,000mAh or more if you're planning to run and charge a number of devices at the same time.
A power bank unit for camping must be able to withstand the rigors of the outdoors and all the challenges it brings. So it should be water-resistant, in case of rain, and robust enough that knocks or drops won't damage it.
Look for multiple charging ports so you can use or charge several devices at once and you don't have to wait until a single one is charged.
See if you can get a specialist power bank for camping that has solar charging. That way, you'll be able to charge the batteries when you're off-grid, giving you further travel independence.
Also consider the size and weight of a power bank you might take along on your next camping trip. If it's too big and bulky and it might cause issues, so look for one that's compact and easy to carry around.
Advantages of Using a Power Bank While Camping
Among the many advantages of having a power bank while camping in remote regions are:
  • Staying Connected: Your safety is paramount when you're in the great outdoors. Being able to call for help in an emergency could make all the difference between saving lives and something far worse. Apart from that, navigation with GPS is critical when getting about on foot in areas you're not familiar with. These devices will need regular charging.
  • Versatility: The latest power banks for camping have lots of added features that let you do more. The BLUETTI AC180 Solar Portable Power Station, for instance, has a hefty 1,800 AC output and 11 ports for devices while letting you control the pack with an app.
  • Eco-friendly: Power banks are the ideal way to go camping without harming the pristine environment you're in. There's no fuel, so no harmful carbon emissions, and no noise to disturb you, neighboring campers or wildlife.
Other Uses for Power Banks While Camping
Many people like to use drones when they're camping, allowing them to capture the stunning natural environment around them and later post on social media. With a power bank for camping by your side, you can keep your power-hungry drone charged at all times, ready to take to the sky for photo or video action at a moment's notice. Drones can also be life-saving.
Depending on the model, you may also be able to use your power bank for Bluetooth speakers. Then you can relax by the campfire in the evening with your favorite sounds.
Want to watch a big-screen movie under the stars -- the ultimate outdoor and private drive-in experience? Plug a portable mini projector into your power pack and watch your favorite films al fresco.
You may also be able to use a portable power pack for camping to ward off one of the most annoying aspects of outdoor life -- bugs. Use an electronic insect repellent to keep nasty insects away, powered through the evening and night with your reliable power bank.
How to Maximize Your Power Bank’s Lifespan During Camping
When you're out camping and mindful of charging your power bank, you will want to make sure you charge it properly, so it delivers maximum juice when you need it. So use solar panels with it if that's possible and be efficient with your charging cycles -- that means charging when the battery is low, which helps preserve battery life.
Shield your power bank from extreme temperatures, of heat and cold, and keep it away from moisture, even if it's water-resistant. And if you're not using various devices, simply turn them off to reduce the amount of charging time and power that's required to keep everything going.
Looking after your power bank for camping, and all your various devices, will ensure you power ahead with an enjoyable outdoor experience.
What Size Power Bank for Camping?
The size of power bank you'll need for camping will depend on what and how many devices you need to keep charged. At the very basic level, if you just want to keep your cell phone charged, you'll need around 10,000mAh.
How Long Can a 20,000mAh Power Bank Last?
You can expect a 20,000mAh power bank to fully charge a cell phone multiple times -- three or perhaps four -- and last for several days without needing recharging itself.
Do Power Banks Lose Charge When Not in Use?
Like all batteries, power banks for camping will lose some power even when you're not using them. The typical range for power loss is between 2 percent and 10 percent per month.
Is It Bad to Leave a Power Bank Charging Overnight?
You can charge your power bank during the night but be mindful of overheating, so charge it in a cool and dry place. Charge during the day if possible, so you can keep an eye on it.
