How to Find the Perfect Camping Generator
If you love camping under scenic skies, you know how crucial it is to pack all your essentials. This includes a portable camping generator that can power up your phone, charge your renovation vehicle, and provide backup during a blackout.
But with so many camping generators on the market, how do you know what power capacity, outage, and size to choose? That’s what we’ll help you with in today’s article! Below, we’ll explore the factors you need to consider to pinpoint the perfect camping generator:
Factors to Consider when Finding the Perfect Camping Generator
Weight and Size
A camping generator’s weight and size can significantly affect its power output and efficiency. Typically, generators with fuel tanks sized 3 to 4 liters can provide 1 to 2 kVA, whereas bigger tanks between 5 to 8 liters can produce 3 to 5kVA.
So, look for a camping generator with enough power wattage to support your charging and appliance needs during your excursion.
Power Output
Whether a camping generator is right for you depends mostly on its power output and surge power. So, to make sure you select the ideal generator, determine the individual wattage consumption of your electrical appliances and electronics.
Next, add them all up to identify your total wattage requirement and start looking for camping generators that offer that power outage.
The Fuel Type
Camping generators are generally of two types:
  • Gas/Propane Camping Generators
A gasoline or propane generator use gaseous or liquid fuel to support your electrical needs without requiring any recharge time. Most gas camping generators include an extension cord so you can move its exhaust fumes far from the campground.
While gas/propane generators offer high flexibility, these tend to be noisy, costly, and harmful for the environment, making them a less popular option for camping.
  • Solar Camping Generators
Solar powered camping generator offer a positive environmental impact and tend to be more compact, lightweight, and quiet as they run on innovative solar panels.
The solar cells embedded within the generator capture and convert sunlight into electrical energy, powering up your RV and electronics. Since there’s no gasoline involved, solar camping generators are a cleaner, more affordable alternative to traditional gas/propane generators.
The best part is, you can run these generators inside your camping vehicle as these don’t release any dangerous fumes.
Dependability and Efficiency
Getting interrupted electrical power to your electronics and recreational vehicle is vital for avoiding potential accidents. So, while surfing through camping generator options, look for a cutting-edge one that offers reliable performance, such as Bluetti AC180 solar generator.
In addition, pick a camping generator with an efficient engine, promising 7 to 8 hours of runtime. This will help you reduce refuel frequencies and enjoy uninterrupted electrical supply.
Noise Level
Camping is all about laying under starry sky’s basking in the tranquil sounds of nature and the soft night breeze. But with anextra noisy camping generator, all you’ll hear is the loud revving over the chirping of the birds.
For this reason, we recommend looking for a generator with a noise level below 50dB. That way, the camping generator won’t hurt your excursion.
Safety and Convenience
Your camping generator is no good if it weighs a ton. Not only will you struggle to carry it, but these are likelier to be noisy. So, look for generators that offer ease-of-use and portability like the Bluetti AC200L.
In addition, make sure your camping generator has safety features, such as an auto-off function to help monitor its carbon monoxide and oil level. This way, your generator will automatically shut down if the emissions or engine heat gets too high.
Top Camping Generators for a Fun-Packed Outdoor Adventure
Now that you know the secrets to finding the perfect camping generator for your next outdoor adventure, let’s take a look at the top few options:
The Bluetti AC180
The Bluetti AC180 is a solar camping generator ideal for those seeking a powerful generator. It offers up to 1152 Wh, a long battery life, and fast charging to ensure you enjoy uninterrupted electrical supply on your camping trip.
In addition,this camping generator has enough power outage to charge your caravan, laptop, phone, and other electrical appliances for a fun-packed camping experience. Lastly, this camping generator is super lightweight, ensuring unmatched portability!
The Bluetti AC200L
If you’re planning to camp with larger appliances, a camping generator with higher power outage is a necessity. The solar-powered Bluetti AC200L offers 2048Wh and a 10-year lifespan, allowing you to plug in all your electrical essentials for longer runtimes.
In addition, this solar camping generator boasts a portable design, allowing for quieter, more reliable, and safer performance. Not to mention, you can combine this powerful generator with Bluetti’s expansion batteries to enjoy the camping experience of a lifetime!
Q1. What size generator should I get for camping?
The choice for a camping generator depends on your required power outage. If you have low electrical needs, such as charging cellphones, a generator that offers 1000-2000 wattage is sufficient.
However, if you plan to use high energy consuming appliances, look for a generator that offers over 3000 wattages.
Q2. How do I know if a camping generator is right for me?
Before buying a camping generator consider your power requirements and battery needs. That way, you can narrow down your options and ensure you select the perfect camping generator.
Q3. What size camping generator is good for a few days of camping?
For camping, a generator that provides 1000-5000 watts should be sufficient. But remember to consider the factors we discussed to ensure you pick one that aligns with your needs.
Still confused about what camping generator you should get? Connect with our experts at Bluetti to find one that aligns with your needs!
