How Many Watts Does a Coffee Maker Use?
Do you love coffee? I know I do. And a coffee maker is a blessing for us coffee-minded people. But have you ever wondered how many watts does a coffee maker use?  Find out how many watts does a coffee maker use, what factors affect its consumption, what chuck it takes from your energy bill, and some great recommendations like switching to solar.
Basic Electrical Terminologies
coffer maker
Before we begin, let us gain an understanding of the basic terminologies about electrical consumption that you will encounter in this article.
Watt (W): Watt is the basic unit of power, equal to one joule per second.
Power: Power is the amount of electricity an appliance consumes at a given time. Hence, how many watts does a coffee maker use refers to the electricity consumed by a coffee maker at one time.
Kilowatt (kW): Normally, the digits of power are relatively high; thus, it is preferred to use kilowatts instead of watts. This is because 1 kilowatt is equal to 1,000 watts.
Kilowatt-hours (kWh): Your utility bill at the end of the month has the electrical consumption in kilowatt-hours. It refers to one kilowatt of power per hour.
The electrical consumption of an appliance is the power usage that makes up your monthly electricity bill.
Energy Consumption Factors For Coffee Makers
Generally, a typical coffee maker uses about 700W to 1,500W, depending on the model, brand, and make. Yet, how many watts does a coffee maker use can vary depending on the type, size, and features of a coffee maker and the time it requires to make coffee. Therefore, you cannot rely on just one factor to ascertain how many watts does your coffee maker use; all aspects matter.
Let’s delve right into them.
1. Type
    Various types of coffee makers are now found in the market. Some examples include drip coffee makers, espresso machines, and single-serve coffee makers. You must own at least one of them, don’t you? Well, the news is that drip coffee makers are the most energy-efficient, i.e., they require the least amount of power to generate coffee.
    Espresso machines are less energy-efficient than drip coffee makers, while single-serve coffee makers need the most power to produce coffee. Undoubtedly, more power consumption means more utility bills.
    2. Size
    It must be cliche, but yes, a larger size requires greater power to make coffee. So, if you own a larger-sized coffee maker, it will definitely consume more electricity when compared to owning a smaller-sized coffee maker.
    3. Features
    Advanced coffee makers now come with super enticing additional features that make you want to buy that coffee maker right away. But wait! What about their power consumption? That’s right.
    Additional features - such as warming plates and timers - will also cost you more in terms of your electricity consumption and, thus, your utility bill. So, better think thrice before directly going for the most tempting coffee maker to buy.
    4. Brew Time and Heating Duration
      How long does your coffee maker take to make coffee? The longer time it takes, the longer the device stays plugged to a socket, the more power it will consume. Naturally, the opposite is also true. The less time your coffee maker requires, the less power it will consume, and the less it will add to your utility bill. Of course, the time duration is not all that matters. Other factors contribute just as much.
      Energy Consumption of Common Kitchen Appliances
      coffee marker
      A kitchen uses not just a coffee maker. Many other devices, such as microwaves, refrigerators, toasters, kettles, blenders, and others, are common electrical appliances used daily in the kitchen. Let us explore how many watts does a coffee maker use when compared to other kitchen appliances, shall we? Coffee makers have an energy consumption rate from 700W to 1,500W. What about the others?
      Microwaves: Microwaves consume 600W to 1,200W of power; thus, they have a similar range to coffee makers. Therefore, microwaves utilize almost the same power that coffee makers do.
      Refrigerators: Our ever-reliant storage device, refrigerators use up merely 300W to 800W of power, much less than coffee makers. Yet, refrigerators work continuously, unlike coffee makers that only remain plugged in for a few minutes. Hence, refrigerators’ power consumption is not exactly less either. Find out the best power generator for refrigerators when there is a power outage.
      Toasters: Ranging from 800W to 1,500W, toasted also lie in the same category of power consumption as coffee makers. Like coffee makers, they, too, consume power only for short intervals.
      Blender: Blenders consume power ranging from 500W to 700W. They also operate for short intervals; thus, blenders consume less power than coffee makers.
      Kettles: Electric kettles have a power consumption ranging from 1,200W to 1,500W. Like coffee makers, they operate for short intervals; their power consumption is similar to coffee makers.
      Kitchen Appliances
      Wattage
      Coffee maker
      700W to 1,500W
      Microwave
      600W to 1,200W
      Refrigerator
      300W to 800W
      Toaster
      800W to 1,500W
      Blender
      500W to 700W
      Kettle
      1,200W to 1,500W
      How Many Watts Does a TV Use? Save Cost Solutions
      How Many Watts Does a Window AC Use?
      Find out how you can easily calculate the power your coffee maker consumes in one usage.
      The Data:
      How many watts does a coffee maker use?
      Time duration required to make coffee
      The average cost per kWh in your area/state
      Example:
      Let the wattage of your coffee maker be:  2,000W
      Let the time duration: 2 minutes
      Let the cost per kWh in your area: 13.19 cents
      Conversions:
      Converting watts to kilowatts: 2000/1000 = 2kW (1kW = 1,000W)
      Converting minutes to hours: 2/60 = 0.03 hours (1 hour = 60 minutes)
      Converting cents to dollars: 13.19/100 = $0.13 ($1 = 100 cents)
      The procedure:
      Power = time * wattage
                 = 0.03 * 2
                 = 0.06 kWh
      The utility bill per one usage = power * cost
                                                     = 0.06 * 0.13
                                                     = $0.0078
      Monthly bill = 0.0078 * 30
                           = $0.234 / 23.4 cents
      Therefore, the cost of making your coffee for 2 minutes with a 2,000W coffee maker is $0.0078 in one usage, while the monthly cost is $0.234. Of course, your monthly bill will vary depending on your frequency of coffee maker usage in one day and in one month, the wattage of your coffee maker, its running time, and the cost of kWh in your area.
      The above is merely an example for you to understand the contribution of your coffee maker to your utility bill.
      Can You Use Solar Generator to Power Coffee Makers?
      Do you wish for a sustainable energy source that will also reduce your utility bills? Solar is your solution. Utilizing the sun’s energy, it is eco-friendly and an inexhaustible power source. No matter how many watts does a coffee maker use, solar devices will keep not only your coffee makers but also your other appliances running for a long time.
      bluetti ac180
      The BLUETTI AC180 Portable Power Station is your go-to solar power station owing to its portability. Along with its remarkable capacity, output, recharge ways, and control app, you will surely love this power station for your home. You can easily place it in the kitchen, effectively powering your coffee maker and other household devices.
      Key features:
      • With a 1,152Wh capacity and a 1,800W AC output, your house will always have the power to operate your coffee makers and other devices.
      • It has 11 output ports, allowing you to plug in your coffee maker, along with many other electrical appliances, at the same time.
      • You can recharge this power station using four ways - AC, solar, car, and generator.
      • You can monitor and control this power station through the BLUETTI app. Convenient, isn’t it?
      BLUETTI AC200MAX + 3*PV200 | Solar Generator Kit
      bluetti ac200max
      You will never be disappointed with the BLUETTI AC200MAX solar generator kit. Whether it is powering up your coffee makers or all your home devices, its capacity, Pure Sine Wave Inverter, battery, and seven ways of recharging will pleasantly satisfy your requirements.
      Key features:
      • Fully charge your AC200MAX with 3 PV200 solar panels!
      • This solar generator kit has a 2,200W AC Pure Sine Wave Inverter and a 2,048Wh Capacity, ensuring a long-lasting power supply for your coffee makers and other devices.
      • A LiFePO4 battery guarantees durability and longevity.
      • This power station can handle 900W of solar input, promising ample storage even for off-grid sites. You can power up your coffee makers and other appliances even when the sun is unavailable or you are off-grid.
      • It has seven ways of recharging - AC, solar, car, generator, lead battery, dual AC, and AC+Solar.
      bluetti ac500
      You will surely love the BLUETTI AC500 Home Battery Backup. Its capacity, battery, ports, and app are simply a chef’s kiss.
      Key features:
      • It has an expandable capacity ranging from 3,072Wh to 18,432Wh, allowing you to use it to power your coffee makers and other appliances for as long as you want.
      • A long-term use is guaranteed with its LiFePO4 battery.
      • It has sixteen ports - you can effectively plug your coffee makers and other devices simultaneously.
      • The BLUETTI app offers you easy monitoring and control of this home battery backup, with both Wi-Fi and Bluetooth connection.
      Wrapping Up
      We all agree we can’t live without coffee, the morning brew, what are you waiting for? Figure out how many watts does a coffee maker use and go for the most sustainable option, which is solar products. The BLUETTI AC180 Portable Power Station, the BLUETTI AC200MAX solar generator kit, and the BLUETTI AC500 Home Battery Backup will never disappoint you with their amazing features.
