BLUETTI New UPS Solar Batteries of 2024
It is quite evident that solar energy solutions are becoming more and more popular. The clear sign is that solar panels have become a common sight for both home and commercial uses. However, some common challenges are solar solutions intermittent nature. It may cause energy fluctuation during bad weather and cannot produce electricity at night.
Luckily,  the all-new BLUETTI new UPS solar batteries of 2024 are here to mitigate these challenges. It will help you harness clean energy, store it effectively, and power your home and commercial spaces anytime. Keep reading to know everything about BLUETTI new UPS solar batteries and other important information.
New BLUETTI UPS Solar Batteries of 2024
Here are the new BLUETTI UPS solar batteries of 2024:
BLUETTI EP900 + B500
bluetti ep900b500
The all-new BLUETTI EP900 + B500 Home Battery Backup is a beast when it comes to storing solar power. It can be paired with solar panels or AC units as you want. It stores and converts the electricity to usable electricity(AC) for all home and commercial needs.
It has a 9,000W power output (good for all light to heavy appliances), which can power all 120V/240V devices. You can scale its storage capacity from 9,920Wh~19,840Wh according to your needs.
Moreover, It features a modular design that can be installed inside and outside as it is IP65 water-resistant. The presence of a premium LiFePO₄ battery, 10-year coverage, BLUETTI APP via WiFi or Bluetooth control, etc., makes it effortless.
One of its striking features is that it sells extra electricity back to the grid, which makes it more budget-friendly. There can be scenarios where you don't use the harnessed energy or may be out of home. In such cases, it sells electricity back to the grid. Moreover, it can be paired with AC units and new and existing solar energy solutions.
It comes with B500, which has a noise level of <25dB, which makes it really noiseless. The premium quality, expandability, flexible options, and modular design make it the perfect energy solution for all needs.
BLUETTI EP800 + B500
bluetti ep800b500
BLUETTI EP800 + B500 is another one of the most amazing battery solutions. It has a great 7,600W power output, which is perfect for all light to heavy appliances. You can expand its energy capacity according to your need from 9900 Wh to 19800Wh with additional battery packs. Also, It can power all 120V/240V devices.
The battery quality is top-notch as it features a LiFePO₄ battery. You can install it with a grid or solar system, which can be new or existing. Moreover, it has taken energy consumption to the next level. It has a smart storage feature that stores energy during off-peak demand to supply you with high demand. This ensures lower bills.
Also, with solar solutions, it smartly stores energy and provides power at night. You can also install it outside as it's IP65 water-resistant. It's a valuable addition to any home with a 10-year warranty, smart control, and other flexible features.
BLUETTI EP900 vs. EP800
BLUETTI EP900 and BLUETTI EP800 are both powerful, scalable, and flexible battery solutions for storing solar energy. However, here are some pros of each, which will help you choose the best ones according to your needs.
Model
Power Output
Battery Capacity
Price
9000W
9.9kWh~19.8kWh
Off grid/ on grid
Starting from US$10,298.00
7,600W
9.9KWh~19.8KWh
Focuses more on off grid living
Starting from US$ 5249.3
BLUETTI EP900:
  • It's great if you have heavy-duty appliances, as its rated power is 9000 W.
  • Its dimensions are 636mm×324mm×368mm, and its weight is 44 kg, which makes it really easy to handle.
  • You can scale it from 9,920Wh~19,840Wh with additional batteries.
BLUETTI EP800:
  • It's good for you if you have an average power need of 7600W, and it can handle light to heavy appliances, too.
  • It's slightly more compact than the EP900 as its dimensions are 626 × 324 × 368 mm and weighs 44 kg.
  • It's scalable from 9900 Wh to 19800Wh.
These home battery solutions best fit small to large homes and even commercial spaces. If you have budget constraints and appliances with average power needs, you can go with the BLUETTI EP800. However, if you have a very high power output demand, then the BLUETTI EP900 with 9000W is amazing.
How Do Solar Batteries Work?
solar generator work
Solar batteries maximize the installed solar energy solutions by storing the surplus energy. The stored energy can be used at night or during bad weather when solar panels cannot create electricity.
The solar batteries work in systematic steps like:
  • Solar panels have various solar cells that absorb sunlight and convert it into Direct Current (DC) electricity. Then, the inverter converts it to Alternating Current( AC) to power home appliances.
  • The extra energy which is not used is directed towards the solar batteries.
  • The battery stores the surplus energy created by the solar panels in the form of chemical energy.
  • At night, the battery discharges and converts the chemical energy to electrical energy.
  • It further converts the DC to AC for various home needs.
The batteries follow this continuous process of storing the extra energy created by the solar panels or power itself from AC units. These batteries with stored power ensure that you face no blackout for any reason.
How to Choose the Best Solar Battery?
Here are some tips for choosing the best solar battery:
Determine power needs: You should assess the power needs of all the appliances in your home, their running time, etc. It will help you choose the right battery with compatible power output.
Check for battery capacity: The battery capacity mentioned in Kwh or Wh is the energy the battery can store. If you face long outages for some reason, you should go for high capacity. Also, choose a battery solution that can be upgraded over time with additional battery packs.
Warranty: It's important to check the running time and warranty of the battery solutions. The more, the better it will be.
Cost analysis: It's advised to choose the budget and then choose the best one in the range. However, the battery solution may have a high upfront cost, but it pays through the years with low bills.
Types of Solar Batteries
Here are popular types of solar batteries:
Lithium-ion batteries
They are the most popular ones due to their high energy capacity. It means it can store more energy in less space. Also, they are more safe, compact and energy efficient. However, it can be costly, but it lasts for years. For example, BLUETTI energy solutions feature LiFePO₄ batteries, which are the best in the class known for their reliability and safety.
Lead-acid batteries
It's widely used for off-grid needs. It has low cost, is efficient, and uses new technology. However, it has low density, which makes it less efficient for home needs.
Flow batteries
They are very large, with around 2.2 MWh of capacity. This size suits them for grid-scale energy storage and industrial applications.
Nickel-cadmium batteries
Nickel-cadmium batteries are great as they can work in extreme temperatures and have high energy density. However, nickel-cadmium is toxic and is banned in certain parts of the world.
How Much Does a Solar Battery Cost?
A solar battery may cost $1,000 and $2,000 per kWh of energy storage. It also depends on the home power needs, the battery capacity, additional battery packs, etc. According to the US Department of Energy, it can range between $12,000 to $22,000. Also, you can get a smaller battery of 8kWh or less for less than $10,000 before installation.
Why Choose BLUETTI?
bluetti battery
BLUETTI is one solution to all power needs, whether in home, outdoor, or even commercial spaces. The BLUETTI features premium batteries, great power outputs, scalability, and storage capacity.
Some of the reasons to choose BLUETTI for home energy solutions are:
  • They feature premium LiFePO₄, which lasts even after significant charge cycles.
  • The BLUETTI solution has great scalability, which means you can expand the battery capacity according to your needs.
  • Many home energy solutions from BLUETTI can be recharged with AC units, solar energy solutions, cars, generators, etc., and other combinations to boost recharging.
  • Many energy solutions have various output ports to charge the appliances directly. For example, BLUETTI EP500 + 3*PV200, solar generator kit, has around 18 well-regulated ports.
  • The App, WiFi, and Bluetooth monitoring help in effortless operations.
  • The amazing warranty periods ensure that your product is safe.
  • One of the most incredible perks is the customer support. You can contact BLUETTI anytime, which offers instant support.
With great flexibility, durability, and easy operations, you can also customize the BLUETTI energy solutions according to particular needs. Moreover, access to power 24/7 with smart storage and supply means peace of mind always.
The UPS solar batteries of 2024 featuring BLUETTI are truly amazing. It's the new path for using clean energy, access to power 24/7, and bringing convenience. You can assess your power needs and unique requirements to choose the best ones. A reliable UPS solar battery will help you store extra energy, save bills, and use cleaner energy. So, go through all the above mentioned factors and bring BLUETTI to your home to elevate the energy solutions.
