5 Best Battery Backup for Refrigerators During Power Outages [2024]
Refrigerators are ideal for keeping food and medicine fresh and safe to consume. However, due to power outages, food and other consumables can become unsafe to consume. It is for this reason you need a battery backup for the refrigerator. Let’s look at the best options you can purchase today.
  • To supply power during outages
  • For food preservation
  • For cost savings
  • Peace of mind
fridge
  • Top freeze refrigerator
  • Side-by-side refrigerator
  • Bottom freezer refrigerator
  • Mini fridge
5 Best Battery Backup For Refrigerators
bluetti ep800
If you are looking for a battery backup for all appliances, consider buying this option. It has up to 19.8kWh capacity making it ideal for running just about any refrigerator. Whether you have a mini fridge or a top-freeze refrigerator, this battery backup will do the trick.
And thanks to its built-in technology, it runs within 20ms after the power goes out. The best part is that you can install it indoors or outdoors. And for peace of mind and convenience, it comes with an app for real-time monitoring.
Like other BLUETTI battery backups, it has a NEMA IP65 rating, making it ideal for use in harsh environments. For safety, the unit has a short-circuit protection feature. You can use it in environments between -20 C and 40 C.
bluetti ac300
If you are looking for a more compact and easy-to-install battery backup for your refrigerator, consider buying this option. Coming in a portable design, it allows you to power portable refrigerators used for camping and other outdoor activities.
With a maximum 12,288Wh capacity, you can rest assured it will power your refrigerator for an extended period during a power outage. You also get at least seven outlets that allow you to power other devices such as smartphones and bulbs. Like other BLUETTI battery backups, it offers fast dual charging of up to 5400W.
The pack has a modular design making it ideal for powering household electronics. And thanks to the built-in inverter it can provide 1800W to 3000W pure AC current. It also allows you to connect two battery backups thanks to the Fusion Box Pro.
bluetti ep500
This is a perfect battery backup for people on the move. With rubberized wheels, it allows you to push it from one spot to another. As such, you can place it in your kitchen or another room when not in use.
The best part is that you can power it using solar, AC outlets, your car, and a lead-acid battery. This means your refrigerator will be running regardless of how long the outage lasts. It has a 5,100Wh capacity meaning it can power small to medium refrigerators.
The BLUETTI power station has several certifications such as FCC and CE, meaning it is safe for use. For peace of mind, you get a 60-month warranty. You get several outputs ranging from USB-C, and USB-A, to RV(Aiation port). And thanks to its compact design, it can fit in small spaces.
bluetti ac200max
Another ideal portable battery backup is the AC200MAX. With a 2,048Wh capacity, you can use it with a mini fridge and a top-freeze refrigerator. It can supply power to a typical 150W fridge for up to 56 hours.
The model comes with seven ways to charge it including AC, solar, generator, and lead battery. What’s more, you can control it using the built-in smart control. Whether you want to power your fridge, electric grill, or air conditioner, the AC200MAX is your perfect bet.
With a 900W maximum solar input, it can recharge within six hours. As such, it is an ideal option for people in places with little sunlight. Not only can you use it with your refrigerator but also with electronics such as laptops, smartphones, and coffee makers. It comes with two expansion ports to boost total power output to 8192Wh.
bluetti ac500
Finally, you can use the 3072Wh model with up to six charging ways. It can be expanded to provide power of up to 18,432Wh. And thanks to its portable design, you can use it for outdoor activities such as camping.
You can connect it via WiFi or Bluetooth allowing for remote control. It is also lightweight, weighing 30 kgs. With a compact design, you can place it on a countertop and connect your refrigerator.
Thanks to the built-in inverter, you get upto 10kW surge allowing you to power most of your devices. The modular design is ideal for maintenance and changing of components. With it, you can run most 240V devices with ease, meaning you’ll spend less on electricity bills. Whether you are at home, camping or enjoying a stay in your backyard, consider buying this battery backup system.
Comparison of 5 Battery Backup For Refrigerator
BLUETTI EP800
BLUETTI AC300
BLUETTI EP500
BLUETTI AC200MAX
BLUETTI AC500
Expandable
No
App
10 years
48 months
60 months
48 months
48 months
Weight
97lbs
47.6lbs
167 lbs
61.9 lbs
66.2 lbs
Input ports
Solar input,
AC input,
DC input
Solar input,
AC input,
DC input
Solar input,
AC input,
DC input
Solar input,
AC input,
DC input
Solar input,
AC input,
DC input
Output ports
6x AC outlets, 1x DC output, 1x USB-C output, 2x USB-A outputs
16x AC outlets, 2x DC outputs, 1x USB-C output, 4x USB-A outputs
10x AC outlets, 1x DC output, 1x USB-C output, 4x USB-A outputs
9x AC outlets, 1x DC output, 3x USB-A outputs
Well, the five battery backup systems for a refrigerator are ideal for different applications. The BLUETTI EP500 Solar Power Station is ideal for powering large models such as side-by-side and bottom-freeze refrigerators.
For small models, the BLUETTI AC500 + B300S and BLUETTI AC200MAX are your best bet. Not only are they portable but produce ample power to run mini-fridges and top-freeze options. The BLUETTI EP800+B500 Home Battery Backup is ideal for powering most of your house appliances during an outage. In short, you should consider your needs before choosing either of the above battery backup systems for your refrigerator.
  • Your refrigerator’s power requirements
Before settling for a battery backup, you should consider the power requirements of your refrigerator. All models have their power ratings, so this is as easy as reading it. Besides, you can find the ratings in the user manual. The ratings are usually in watts (W).
  • Consider the battery type
  • Battery capacity
  • Monitoring and control
If you’ll be away for an extended period, consider purchasing a model with remote control capabilities. This allows you to monitor its performance from anywhere. Look for features such as mobile apps and digital displays.
