Whole House Generator Cost: Installed Price, Sizing, and Ongoing Expenses
A whole-house generator installation can cost about $8,000–$16,000 for a typical residential project, with larger systems or complex site work costing more. The budget depends less on square footage than on which loads must run, their starting demand, fuel setup, and how complex the property is to connect.
A standby generator is not a single-price appliance. The same generator can produce different quotes depending on service-panel location, fuel availability, trenching, permitting, and whether the design powers every circuit or only selected loads. For a useful whole-house generator cost estimate, separate equipment, installation, and ownership costs before comparing quotes, and confirm local inspection requirements before signing a contract.
How Much Does a Whole House Generator Cost Installed?
For many residential projects, an installed budget of about $8,000–$16,000 is a useful starting point. Generac’s installation guide publishes that range, including the generator, system equipment, materials, and installation. Larger standby units and extensive gas, electrical, or site work can push the total higher. Angi’s 2026 cost guide lists roughly $5,000–$18,000 for 22–48 kW equipment before installation.
A practical home generator cost estimate treats the generator as one line item. A replacement at a prepared site can cost far less than a first installation requiring gas work, transfer equipment, trenching, and service upgrades. Compare bids by scope so excluded work does not make a quote look artificially low.
| Project element | Published 2026 planning figure | Why it varies |
| Whole-house standby equipment | $5,000–$18,000 | Output rating, fuel type, controls, enclosure |
| Installation and labor | $1,500–$5,000 | Panel work, trenching, gas work, site complexity |
| Transfer-switch wiring | About $1,200 | Switch rating, service configuration, load management |
| Pad / site prep | About $1,000 for a 3 × 6 ft pad | Concrete, grading, drainage, access |
| Permits / inspections | $50–$200 for permits; confirm local inspection fees | Local jurisdiction and trade permits |
The component figures above are planning examples from Angi’s September 2026 guide. They are not automatically additive: a package or installation charge may already include switching, permits, or site work. Ask the contractor to identify included items before totaling the quote.
For a preliminary budget, add the generator equipment price, installation labor, and any separately quoted transfer equipment, fuel-system work, site preparation, and permit costs. Subtract items already included in a package quote to avoid double counting. For example, a hypothetical project might include a $7,000 generator, $3,000 in installation labor, $1,500 in fuel-system work, and $1,000 in additional site preparation, totaling $12,500 before other required charges.
Illustrative cost calculation: $7,000 + $3,000 + $1,500 + $1,000 = $12,500.
What Is Included in a Whole House Generator Installation Quote?
A complete quote should identify the generator, switching equipment, site work, fuel connection, electrical labor, permits, startup, and optional maintenance. Compare scopes, not just generator prices.
Generator and Transfer Equipment
The equipment package normally includes the standby generator, controls, and an approved transfer arrangement. Transfer equipment manages utility and generator power so the home is not backfeeding the grid. Ask whether load-management modules, cold-weather accessories, batteries, or monitoring hardware are included or separate. Those details can materially change a home standby generator cost comparison.
Site and Fuel-System Preparation
Site work may include a pad, grading, drainage, trenching, and gas or propane piping. Existing adequate fuel service and an accessible location usually reduce cost; long trenches, regulator changes, a new tank, or difficult access increase it. Setback, ventilation, flood exposure, and maintenance access also affect placement.
Electrical Work, Permits, and Inspections
Electrical labor covers transfer equipment, feeder conductors, grounding and bonding, circuit changes, testing, and commissioning. Some homes also need service-panel modifications or a selected-load subpanel. Permit and inspection requirements vary locally, so a useful whole house generator installation cost estimate includes the electrical and fuel trades rather than a national flat installation fee.
Which Factors Change the Cost of a Whole House Generator?
The biggest cost drivers are the loads being supported and the work required to connect the generator. Two homes with the same floor area can need different equipment if one uses gas heat while another has electric resistance heat, a well pump, multiple air conditioners, or other large loads.
Household Loads and Starting Demand
Generator sizing begins with watts, not square feet. Refrigerators, pumps, compressors, and air conditioners can draw higher starting current than their running load. A load calculation should separate running demand from realistic motor starting demand and identify circuits that can be shed. Oversizing adds cost and fuel use; undersizing risks overloads or unwanted load restrictions.
Fuel Access and Property Layout
Natural gas can simplify fuel storage but may still require meter or piping review. Propane systems need adequate tank capacity, regulators, and space. Long distances between the generator, fuel source, and service equipment increase trenching, conductor, and pipe costs. Setback, ventilation, noise, flood exposure, and service access can also constrain the site.
Labor Rates and Electrical Upgrades
Older homes may need panel work, service upgrades, grounding corrections, or circuit reorganization before a generator can be integrated. Labor rates also vary by market. If a quote includes electrical modernization, separate that work from the generator line items so you can see how much of the budget addresses existing infrastructure.
Warranty, Service, and Load Management
Extended service agreements, remote monitoring, cold-weather kits, and load-management hardware increase upfront cost. Load management can sometimes let a smaller generator serve a home by preventing large loads from starting together. When using a whole-house generator cost calculator, list those options explicitly rather than treating generator kW as the only variable.
How Much Generator Capacity Do You Actually Need?
Capacity should be based on a prioritized load list. Add the running watts of equipment likely to operate together, then allow for the extra starting demand above a motor’s normal running load. A home supporting refrigeration, lights, internet, and a furnace blower can need far less output than one running electric water heating, cooking, central air, a well pump, and other heavy loads simultaneously.
For an initial capacity shortlist, use these residential standby tiers from a manufacturer’s sizing guide, then have the installer match them to your actual loads:
- Around 10 kW: essential circuits such as refrigeration, lights, and small appliances, with major electric heating and cooking loads excluded.
- 14–18 kW: essentials plus selected higher-demand equipment, such as a well pump or central AC, where starting demand and load management permit.
- 20–28 kW: broader household coverage with more large loads; multiple HVAC units or substantial electric heating may require a larger engineered system.
For a standby system, a qualified installer should verify the load calculation, transfer equipment, service rating, fuel supply, and code requirements. The question “how much does a whole house generator cost?” is inseparable from what the home must power. Reducing the backed-up load list can reduce generator size and installation complexity. A generator described as “whole-house” does not necessarily mean every high-demand appliance can operate simultaneously; the actual load calculation and load-management configuration determine the coverage.
What Ongoing Costs Should You Budget For?
The purchase price is only part of lifecycle cost. Standby generators consume fuel, exercise periodically, require scheduled service, and contain batteries and wear items that eventually need replacement. Estimate annual ownership cost by combining scheduled maintenance, exercise fuel, expected replacement items, and an allowance for actual outage fuel use.
Fuel During Outages and Exercise Cycles
Fuel use rises with load, engine size, and outage duration. Manufacturer fuel-consumption tables are more useful than a generic gallons-per-hour assumption. Exercise cycles also consume some fuel. With propane, estimate how long the tank can support the expected load and consider whether fuel can be replenished during a regional emergency.
Routine Maintenance and Service
Engine oil, filters, spark plugs, inspections, and periodic professional service should be budgeted. Service intervals depend on the model and operating hours, so a long outage can trigger maintenance sooner than the calendar suggests. If considering a service contract, compare which visits, parts, emergency callouts, and response times are actually included.
Battery, Consumables, and Long-Term Repairs
Most standby units use a starting battery that ages even when the engine runs rarely. Belts, hoses, sensors, chargers, and control components can also fail over time. When comparing whole-house backup generator cost, include likely maintenance and replacement items over several years instead of treating the installation invoice as the full ownership cost.
Build a Flexible Home Backup System With BLUETTI
Engine generators are one route to long-duration backup, but some households prioritize silent indoor operation, stored electricity, and solar recharging for selected circuits and appliances. A modular home battery backup system can be sized around critical loads rather than the entire service, which changes both the cost structure and day-to-day use case.
The BLUETTI Apex 300 delivers 3,840 W of AC output and 2,764.8 Wh of battery capacity, with simultaneous 120 V and 240 V output. It can support demanding household equipment within its rated power limits, making it useful for homeowners who need reliable backup for essential appliances during an outage. Its expandable design also allows households to build a larger energy reserve as their backup requirements develop.
- Smartest 120V/240V Portable Power
- 3,840W | 2,764.8Wh | LiFePO₄
- 0ms UPS Response Time
- 6,000+ Life Cycles to 80% Capacity
- Dual Voltage Output & Expandable Storage
- Ideal for Smart Home Energy Management
For extended outages, the BLUETTI B500K adds 5,120 Wh of LiFePO4 battery capacity to a compatible Apex 300 system. This additional storage can help maintain power for essential equipment over longer periods, particularly when several hours of backup are needed. The modular approach also gives homeowners flexibility to expand stored energy without replacing the main power station.
B500K for Apex 300
- 5.12kWh Battery Capacity
- 4,000+ Life Cycles / Up to 10-Year Lifespan
- Scalable System Capacity up to 100kWh
- Compatible with Multiple BLUETTI Power Stations
- Flexible Wall-Mounted or Trolley Setup
The BLUETTI Elite 400 combines 3,840 Wh of built-in capacity with 2,600 W of AC output. Its integrated wheels and handles make it convenient to move between locations, allowing households to position backup power near the appliances they need. With up to 1,000 W of compatible solar input, it also supports daytime battery replenishment when sunlight is available. This makes it practical for powering selected household essentials while maintaining flexibility during an outage.
- Perfectly Sized Solar Generator: 3,840 Wh capacity, just right for home backup and outdoor adventures.
- Wheels and handles for easy transport
- High Output: 2,600 W rated, 3,900 W lifting power
- Ultra-low 3 W standby draw extends runtime
- 15 ms UPS switchover during outages
For households interested in renewable backup power, a BLUETTI solar generator kit combines battery storage with compatible solar panels. Solar charging can help replenish stored electricity during extended outages, depending on weather, available sunlight, and system input limits.
When planning a backup budget, consider the battery system, compatible solar panels, any necessary accessories, and professional electrical integration where required. By selecting a setup around the appliances that matter most, homeowners can create a practical backup solution that supports everyday comfort and essential electricity needs without committing to a full-house standby generator installation.
A realistic whole-house generator budget separates equipment, installation, fuel infrastructure, permits, and service. The final price depends on backed-up loads and required property work. Compare quote scope line by line and confirm the load calculation. Battery backup is another option when the goal is selected critical loads rather than every household circuit, especially where quiet operation or solar charging matters.
Frequently Asked Questions
It can add buyer appeal in areas with frequent outages, but there is no guaranteed dollar-for-dollar return. Value depends on local outage risk, installation quality, maintenance records, permits, fuel setup, and the buyer’s priorities. Keep documentation for the generator, transfer equipment, service history, and inspections so a future buyer can understand what is installed.
